What "toe-in" settings for 87 CRX with Ground control and Tokicos?
Suspension Experts:
What toe-in settings would you recommend for an 87 CRX that is lowered 1 1/2 inches with Ground Control Coilovers in the back and Tokico 5 ways all the way around. I am running 195/50 VR 50s on 15x7 rims..
Thanks, all
Thanks, all
Toe-In is the devil! You want toe out, about 1/8" is a good safe amount without affecting tire wear dramatically.
Add 1.5 degrees of negative camber in the front, and set the caster forward about 3 degrees. Get the rear as close to zero as possible on all settings.
This should be the perfect setup for street/autox duty. Quick turn in and reduced understeer.
cyberx
10
Mar 28, 2003 12:18 AM
crxforum
17
Dec 31, 2002 09:31 PM
