Need help with reducer
Old Aug 31, 2008 | 06:31 PM
tmramsburg's Avatar
Default Need help with reducer
I bought paint from paintscratch.com. They sent me ppg base and clear. base is deltron 2000. clear is duracryl dca-468. Do i reduce with automotive thinner?
Old Aug 31, 2008 | 08:10 PM
bakertime's Avatar
Default Re: Need help with reducer (tmramsburg)
You should follow manufacturer recommendations.
Old Aug 31, 2008 | 09:35 PM
tmramsburg's Avatar
Where can I find that info?
Old Sep 1, 2008 | 08:47 AM
tmramsburg's Avatar
ppg is closed til tuesday. can anyone help me out? i want to get this stuff today.
Old Sep 2, 2008 | 02:36 AM
mugencivic94's Avatar
Default Re: (tmramsburg)
it uses a "DT" reducer and you have to use according to temp. so if it was in the 55-65 range good to use DT860 or in the 68-78 range DT870, then 78-88 DT885 and their slowest reducer for the hot days is DT895 but if its over 100 then you should add a lil DT898 which is a retarder
Old Sep 2, 2008 | 03:02 PM
tmramsburg's Avatar
Thanks. I just got the instructions on it. Can you tell me if Deltron2000 dbc base is compatible with Duracryl DCA468 clear. When I was reading about them, no where did it say they were compatible. I think I just got bent over by paintscratch.com.
Modified by tmramsburg at 4:27 PM 9/2/2008
Old Sep 3, 2008 | 06:09 PM
NotNew's Avatar
they are compatible. Not sure why your using a laquer clear with all the urethane's out these days but they are both PPG you should have no problems.
msinsky14
Paint and Body
Jun 7, 2007 03:24 AM
oldskooljdm
Nov 25, 2003 11:06 AM
AamirCWITR
Nov 8, 2002 04:19 PM
AssPenny
Jul 29, 2001 09:56 AM
