Sloppy linkage.. where to find a new sleeve?
Old Aug 31, 2008 | 05:49 PM
Maxcapacity's Avatar
Default Sloppy linkage.. where to find a new sleeve?
My shifter is so sloppy loose.. I was under the car and noticed on my hasport b series linkage, there is a pivot point just before the collar where the bitch pin is..
That swivelling joint has a metal pin that is crushed in so I will have to drill the head off or cut it off.. there used to be a plastic sleeve that went over the pin to make it solid in the pivot joint,now after 2 years it has completey worn down to nothing but metal.
Is there a place that sells replacements? or what?
Old Aug 31, 2008 | 05:58 PM
Crx Jimmy's Avatar
Default Re: Sloppy linkage.. where to find a new sleeve? (Maxcapacity)
contact hasport they will send you a new bushing free of charge, or if you have the old d linkage you can pillage it for parts
Old Aug 31, 2008 | 06:03 PM
Default Re: Sloppy linkage.. where to find a new sleeve? (Crx Jimmy)
Thanks man, I hope they will send me a whole new pin with it so I can press it in or else i'm stuck using a bolt with the new collar..
ChristopherJaso
Transmission & Drivetrain
Jun 9, 2012 04:56 PM
SlowPokeEg
Aug 21, 2011 10:00 AM
WGFletch4WS
Jun 6, 2011 05:55 PM
EF_ST@TUS
13
Aug 20, 2006 12:50 PM
civickiller
Jan 1, 2006 04:56 PM
