Will ITR front tophats work on the rear?
Old Aug 31, 2008 | 04:34 PM
opeth13's Avatar
Default Will ITR front tophats work on the rear?
I searched the forums and I don't think this has been covered. I'm trying to sell my front ITR tophats (solid bushings) and a member wants to know if they'll work on the rear. ITR's only had the solid bushings on the front tophats, correct? Would the front tophats work on the rear? I don't see why they wouldn't as the shock rod and bushing hole diameters should be the same front to rear right?
Old Dec 16, 2008 | 08:35 PM
Kusai.Nihonjin.Desu's Avatar
bumping an old thread for info
Old Dec 16, 2008 | 09:27 PM
Spec R's Avatar
the one piece tophat bushings are on both the front and the rear.
as far as using the front ones for the rear, i've never tried that.
Old Dec 17, 2008 | 11:15 AM
sackdz's Avatar
I'm not sure about the OEM parts, but I made a set of upper pillowball mounts and the front and rear seating and bolt dimensions are the same
Old Dec 17, 2008 | 01:14 PM
cjames235's Avatar
they will probably work but the rears have a slightly different shape to them and use a rubber gasket on top of them to seal them against the body
Hiroshima_VTi-S
Honda S2000
Oct 10, 2007 11:26 AM
91sicrxer
21
Jun 14, 2005 04:19 PM
