Parking (e-brake) brake cables - Which ones do I have?
I went to hook up the parking brake today on my 88 CRX si project and came to find out that nothing lines up right. So which cables do I have? are these from a teg or are they infact 88 CRX cables or what?
one of the cables found in the 88 CRX Si. They were under the car dangling. See how long they are!
Under the car this is how it lines up to the bolt holes.
I have a 91 CRX HF as a parts car. Can I use
I'm starting to really hate this car
From: Staring down the barrell of my 12 ga. Texas, USA
dont the si models have rear disc, and the hf/dx have rear drum? cause that wont work.
thats the only thing i can think of
Whats wrong with the cable in the pic? you have to bolt it down with the bracket. the cable is also fully extended pull on the cable from the other side thats why it looks long
Even if you push the cable back as far as it will go it isn't close to enough. That along with the mounts under the car not lining up tells me this is the wrong part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">not sure what the cable is from..
Do you have the bracked that holds down the ends of the cable?</TD></TR></TABLE>
yes i do.
yes i do.
LankorDie
Jul 16, 2015 04:50 AM
TheHatchHog
Aug 24, 2003 06:41 AM
