Im having a bad day.
Old Aug 31, 2008 | 04:09 PM
slvrcvc93's Avatar
Default Im having a bad day.
This a motor I recently rebuilt it Snapped a rod in half with only 13 miles on it. I also bent an exhaust valve
Old Aug 31, 2008 | 04:21 PM
redef90si's Avatar
Default Re: Im having a bad day. (slvrcvc93)
ouch sorry to hear man
Old Aug 31, 2008 | 04:26 PM
NOFX's Avatar
H-T White Ops
Old Aug 31, 2008 | 04:27 PM
StreetRacinThug's Avatar
Who ever did the work didnt do it right! Sorry to hear
Old Aug 31, 2008 | 04:29 PM
dohczccrx's Avatar
Default Re: (NOFX)
well you know what they say . practice makes perfect
Old Aug 31, 2008 | 04:33 PM
BryanM.'s Avatar
Resident Gearhead
That sucks.
Every time I see this it makes me feel about rebuilding my B16A. No wonder I've been procrastinating.
Sorry for your loss, I hope your next one is bulletproof.
Old Aug 31, 2008 | 04:37 PM
SpeedoKing's Avatar
ouch sorry man that makes me cringe jus looking at
Old Aug 31, 2008 | 04:45 PM
slvrcvc93's Avatar
Default Re: (mcvtec)
Its funny you say that this motor came out of anyone of my own cars i was the one that did the rebuild. I know what everyone is going to think but this is not my first rebuild but it is the first that snapped a rod right in the middle don't ask me how because I know the stock rods are good for over 300 whp. I cant call it bad luck but I am really upset.
No worries though I already had a spare block that was rebuilt a while back I took it out of my car. It was a 92 ls, But I was hoping to use it for my ls-vtec setup I was about to do but I guess this will have to be done right now. I have several motors in my house right now anyway I have a jdm b16 but i need to replace the valve stem seals. I have my turbo gsr motor that needs rings ( that's where the original block came from)
I bought the bottom end from a friend it already has forged rods pistons and rings with a block guard and a Type-R oil pump. So I used this gsr block with another b16 del-sol head I picked up from a friend. But its ok the coupe will have to wait I'm going to focus on my autocross hatch so I can put in a 2000 single cam turbo.
Old Aug 31, 2008 | 04:57 PM
EX-T's Avatar
Default Re: (slvrcvc93)
Was this one boosted or anything?
Old Aug 31, 2008 | 05:10 PM
slvrcvc93's Avatar
Default Re: (EX-T)
No this was for Just a simple O.E. rebuild and this block has never evr been boosted for the 5 years that I have had it or prior.
Old Aug 31, 2008 | 05:27 PM
EkFG's Avatar
were you reving the **** out off it when this happen. i wanna find out the problem. did you notice anything about that rod when you did the rebuild?
Old Aug 31, 2008 | 05:28 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
eh 13 miles??
id say inproper rebuild. I mean look at the cylinder wall on the left- huge grooves down it, buildup on the top- did you even hone the cylinders? I see no cross hatch-
What were your P/W clearances?
what were you rod bearing clearances?
Old Aug 31, 2008 | 05:44 PM
slvrcvc93's Avatar
Default Re: Im having a bad day. (nytosc)
funny you say that i honed the **** out of it and Ill be honest I think it was improper rebuild to I wont lie. I haven't taken the pan off so I want to see the condition of the rod. I could be wrong but this is what I think happened. If anyone has rebuilt a motor you will know what im talking about.
When I put the motor together I always start cylinder no1 and over to 4. When I got to 3 I flipped the motor upside down and the rod bolt slid up a little so I checked it and fixed it and torqued it down. I am assuming the same happened to cylinder 1 but I never rechecked it. So that is where I F*ed up. I usually check my work 2 maybe 3 times and I didn't. This is a lesson learned no matter how many times you have done the same thing always go back and check again and again for good measure. and the cylinder no 4 looks like that because i have had it without a head for a couple days now.
Old Aug 31, 2008 | 05:45 PM
Snailor Built's Avatar
engine really doesnt like you
Old Aug 31, 2008 | 05:48 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (30lb_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30lb_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">engine really doesnt like you</TD></TR></TABLE>
Horrible first post
EX-T's Avatar
So you think it's cuz you didn't have the rod bolt torqued right?
Old Aug 31, 2008 | 05:53 PM
slvrcvc93's Avatar
Default Re: Im having a bad day. (EX-T)
could be or maybe the rod bolt slid up a little and I didn't notice or maybe I over torqued it. I will know more when I pull the pan off so I can see the dead remains. Ohh and EKFG I wasn't not revving it up i need to brake her in so i knew to keep it under 4k for at least 500 to 1000 miles.
Old Aug 31, 2008 | 06:00 PM
eg2jr's Avatar
that sucks
Old Aug 31, 2008 | 06:16 PM
nytosc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcvc93 &raquo;</TD></TR><TR><TD CLASS="quote">funny you say that i honed the **** out of it and Ill be honest I think it was improper rebuild to I wont lie. I haven't taken the pan off so I want to see the condition of the rod. I could be wrong but this is what I think happened. If anyone has rebuilt a motor you will know what im talking about.
When I put the motor together I always start cylinder no1 and over to 4. When I got to 3 I flipped the motor upside down and the rod bolt slid up a little so I checked it and fixed it and torqued it down. I am assuming the same happened to cylinder 1 but I never rechecked it. So that is where I F*ed up. I usually check my work 2 maybe 3 times and I didn't. This is a lesson learned no matter how many times you have done the same thing always go back and check again and again for good measure. and the cylinder no 4 looks like that because i have had it without a head for a couple days now.</TD></TR></TABLE>
how many steps were you doing to torque the rod? sometimes ya forget to compelte a step or somethign ya know?
Old Aug 31, 2008 | 06:40 PM
dangthemang's Avatar
wow that really sucks. gl with the rebuild..
Old Aug 31, 2008 | 06:56 PM
egallmotor12's Avatar
watever you do dont rebuild yourself your nuts
Old Aug 31, 2008 | 07:01 PM
slvrcvc93's Avatar
Default Re: Im having a bad day. (egallmotor12)
I have been building motor by myself for over 8 years believe me unlike you I know what I'm doing. I might have missed a step like I said i just got to comfortable. Just goes to show you like I said check and recheck your work.
Old Aug 31, 2008 | 07:20 PM
redef90si's Avatar
The fact that you admit it was your mistake and tell us the reason it F**ked up shows your a classy tuner; as for egallmotor unless your perfect i wouldn't say ****
Old Aug 31, 2008 | 07:30 PM
Mugen112's Avatar
yeah.. sounds like a simple mistake, not a bad rebuild. Bad rebuilds usually last a few thousand miles until they're back to where they were before the rebuild. Definitely check the pan to see what remains.
Old Aug 31, 2008 | 08:17 PM
roycivic92's Avatar
b20 vtec time.
