SFWD Selloff: FastLine, Lensos, Full Race kit, Konis, Skunk2 Drag, Paxton Pump(A1000), DSS Axles, Bu
Hello! Most pics were taken on my crappy phone camera, so please excuse the crappyness
Prices do not include actual shipping. Would prefer local pickup but am willing to ship, and am not parting anything out quite yet but feel free to PM me. If you have any pricing suggestions please PM me so that I can adjust accordingly. All prices are OBO. Thanks for looking.
Full-Race Stage 3 Turbo Kit. Non-AC. I really liked this setup and it did very, very, very well. Its a heat coated Pro-Street ram-horn T3 with a T3/T61 turbo. The turbo has a polished compressor housing, heat coated turbine housing(no-rust), 360 degree bearing, and clipped turbine wheel(more lag/more high end power), and fully balanced rotating assembly at Turbo Specialties.
I've made 580 uncorrected whp and 420lb/ft with this turbo setup, and the boost holds wonderfully(The turbo was supposed to max out at 520whp but the upgrades helped tremendously). Ran a best of 10.20@147 and was still getting it dialed in. To my knowledge, this was the second fastest T61 FWD and the fastest without a wheelie bar.
38mm Tial wastegate, and Tial BOV. Custom aluminum intercooler piping 2.5 hot side --> 2.75 cold side. -4 AN stainless steel braided Oil Feed and -8 AN Oil Return with all necessary fittings. Full 3" stainless downpipe with 3 O2 bungs for whatever. Custom made dump tube dumps behind the engine bay too keep the EGR to a minimum. Last but not least, it will come with a Precision 750hp intercooler 2.75" inlet/outlet in mint condition. Everything needed including T-bolt clamps and silicon hoses: $2600
This kit vs my little D15 EF... hehe just screwing around on the dyno...
Fully built B20C1 engine swap. Dyno and times posted above.
<U>Block</U>
Carrillo rods, 84mm CP 9:1 pistons, Darton MID Sleeves, new Oil/Water pumps, King Bearings, ARP Head studs and Main studs, Fully balanced rotating assembly, Honda timing belt(and new spare), GE modified Honda 84mm headgasket, Z10 block plug, Endyn crank case ventilation adapters(with bezels), -8 AN bulkhead on oil pan for return.
<U>Head</U>
Fully ported and polished for big turbo build, 5 angle valve job, Skunk2 Titanium retainers, Skunk2 valve springs, GSR cams, Edlebrock intake manifold, Hondata I/M gasket, Holly 70mm aluminum throttle body, ZHL map sensor block off, 1000cc precision injectors(with resistor box), 8K mile used OEM distributor, AEM Cam Gears, fresh NGK Blue spark plug wires.
<U>Tranny</U>
GSR Trans with OEM ITR Helical differential, Clutchmasters stage 4 pressure plate with 6 puck unsprung ACT puck, 8.8lb Clutchmasters flywheel, OEM starter, GE scatter shield(per NHRA/NDRA rules) Still shifts wonderfully, the syncro's went bad on the original tranny and this was the replacement at the end of the 2007 season. Hasnt been raced in the 08 season(I moved).
<U>Misc</U>
Also comes with alternator, fuel rail, all timing belt covers(its moon cut for the gears), any spare B-series anything(i'm transitioning to K-series), mounts and mount bushings, along with fully filled mounts for extra torsion resistance. If needed, can throw in my GSR shift linkages. Engine harness has been retaped and is included. Motor has 130k miles total and was built at 110k miles(Was a street car until traction became a joke). Never run without having a well matched tune, and appropriately gapped/ranged spark plugs. Oil has always been Mobil 1 10W30. This setup has been enormously reliable, and I have been nothing but impressed with its power output: $4700 for entire swap
Fast Line Performance shifter(I loved this thing): -SOLD(That was fast)
4 Lenso 13X7.5 wheels with 205X60-13 Advan A048R's with 3/4 tread left. Wheels condition is 9/10. These tires have great grip and the sizing was perfect for my CSP EF. Wheels will also fit over GSR brakes(Awesome setup for the D-series Solo folks): $900
Authentic Mugen Strut tower bar. No sticker, great condition: $160 - Pending!
13X7 steel wheels. Great for the A/M drag guys who want to try out the 13' sizing. Not quite as feathery as the Lenso's, but they are not bad at. And you can fit some good sized track tires on there(do not fit over GSR brakes
): -SOLD Thanks!
Paxton fuel pump. This is the same pump as the Aeromotive A1000, just different housing. Good condition and low hours: $250
EG/DC etc... Driver seat bracket with Sparco Sliders all ready mounted. Good shape, sits low, and slides smoothly: $100
Drive Shaft Shop 3.9(new Stage 5's) Axles and hubs(B-Series). The hubs are already pressed and will be sent with the axles. Rated to ~600whp. Wonderful system and haven't heard a peep from them ever(gonna miss these
) : - SOLD
Russell's SS fuel line. Goes from OEM fuel filter --> OEM fuel rail(two banjo fittings) Fuel pressure gauge included: $100
I'll update with more items when i get back, I'm hungry
Edit: I'm back. The DNC made D-town Denver nuts so we went to the taste of CO. Pretty cool shin-dig.
Skunk2 Drag springs. 900lbs 2.5"X7" : $125
EF Koni sport fronts+rears only on for a month or so. Will sell with sleeves 550lb, springs, and top hats(fully assembled and of of my 91 EF pictured above): - SOLD
K20A A/C compressor motor had 9K miles on it: $200
Modified by TheMidasTouch at 6:06 PM 9/10/2008
<U>Block</U>
<U>Head</U>
<U>Tranny</U>
<U>Misc</U>
): -SOLD Thanks!
) : - SOLD
4700 for the entire swap seems to be about what I've settled on. For just the Long block though(if i decided to part everything out) It would probably be 2900. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMidasTouch »</TD></TR><TR><TD CLASS="quote">EF Koni sport fronts only on for a month or so. Will sell with sleeves and 550lb springs. Can throw in the rears if really needed: $200</TD></TR></TABLE> I'm interested... you have rear springs or rear shocks?? I am looking for a set of Konis for my CRX, already have springs though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMidasTouch »</TD></TR><TR><TD CLASS="quote">Thank you ma'am!</TD></TR></TABLE>
fixed
thanks, can't wait to install them!
fixed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MXS »</TD></TR><TR><TD CLASS="quote">
fixed
thanks, can't wait to install them!</TD></TR></TABLE>
LOL, I'm sorry
Have fun!
fixed
LOL, I'm sorry
Have fun!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cojak23 »</TD></TR><TR><TD CLASS="quote">nice!!!</TD></TR></TABLE>
Thank you! If you like anything make sure you
WHAT!! Your selling the charge piping....
You need to hang those pipes on the IFO trophy
I want the Lensos call me!!
I repeat...
( I would call you but I got a new phone and for some reason all my #s didn't transfer on the sim card
I repeat...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">WHAT!! Your selling the charge piping....
I'm sorry man!
They wont work on my K build
I PM'd ya!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMhEaD »</TD></TR><TR><TD CLASS="quote">Bump for Mike, his stuff is nothing but the best.</TD></TR></TABLE>
Thank you sir!
I'm sorry man!
I PM'd ya!
Thank you sir!
Good morning!
Wheels and Koni's shipped on Saturday! Axles are sold! Lenso's Pending!
