HELP! Putting a new motor in.
Old Aug 31, 2008 | 11:59 AM
kambosoup's Avatar
Default HELP! Putting a new motor in.
I have a 90 Civic SI. I just recently got. I have a d16a6 block with a vtec head. I was wondering what parts were needed to put it in. Do I need to get a different harness for the motor? Any help anyone!!!!
Old Aug 31, 2008 | 12:09 PM
kalm_traveler's Avatar
Default Re: HELP! Putting a new motor in. (kambosoup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kambosoup &raquo;</TD></TR><TR><TD CLASS="quote">I have a 90 Civic SI. I just recently got. I have a d16a6 block with a vtec head. I was wondering what parts were needed to put it in. Do I need to get a different harness for the motor? Any help anyone!!!!</TD></TR></TABLE>
D16A6 so you are using your stock block?
which VTEC head?
Old Sep 1, 2008 | 06:54 PM
kambosoup's Avatar
Default Re: HELP! Putting a new motor in. (kalm_traveler)
im using a z6 head. I heard I would be able to use a crx si harness. Im not sure if it will work though. If anyone has some insight, please shine in. Thanks.
Old Sep 1, 2008 | 10:54 PM
D16SiHatch's Avatar
you utilize your stock harness. then get a obd0 to obd1 conversion harness and run the subharness into the engine bay to connect to the sensors that the z6 head has, which the stock a6 did not have. then get yourself a stock p28 ecu.
i was going to link you to the 2 links in the faq section about doing a mini-me swap but neither of them seem to be working..
Old Sep 1, 2008 | 10:55 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: HELP! Putting a new motor in. (D16SiHatch)
if you are swapping to a z6 head i'd highly support you going to obd1.
http://www.boomslang.us for the harness and FAQ for what else is needed and how to install.
TravisCadello
Feb 10, 2015 02:27 PM
Sean EgHatch909
Apr 23, 2013 01:06 AM
slipperyduck
Sep 17, 2006 03:11 AM
