Will a 88-89 CRX cluster work in a 91 Civic Hatch?
Old Aug 31, 2008 | 09:46 AM
LickyMYwalker's Avatar
Default Will a 88-89 CRX cluster work in a 91 Civic Hatch?
imn lookin to get a 88-89 CRX Cluster with a tach on it and put it into a 91 civic hatch. will it be a as simple as to just take old one out and swap? also is there a harness already for the tach?
http://www.passwordjdm.com/pro...D=234
that would be the cluster im looking at.
thanks guys!
Old Aug 31, 2008 | 12:11 PM
apekd's Avatar
Default Re: Will a 88-89 CRX cluster work in a 91 Civic Hatch? (LickyMYwalker)
88 to 89 clusters use the 88 to 89 gauge pod, the 90 to 91 use the 90 to 91 pod. so swapping out the clusters means that you need a different pod. and the plugs will work. i had a 91 crx si cluster in my hatch, just didnt put the gauge pod over it, now im running a 89 crx si cluster with my stock holder. so yes it will work with the stock plugs but just get the 90 to 91 holder
also, if you are trying to get that exact cluster to work, good luck, you have to wire up the VSS which takes some time and is a butt to do....i suggest just getting a USDM si cluster and then doing the jdm speed gauge swap, meanin you find the guy on ebay who makes them or make your own that reads out in kilometers and not miles.....photoshop would be your best friend here
Old Aug 31, 2008 | 12:21 PM
kalm_traveler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LickyMYwalker &raquo;</TD></TR><TR><TD CLASS="quote">imn lookin to get a 88-89 CRX Cluster with a tach on it and put it into a 91 civic hatch. will it be a as simple as to just take old one out and swap? also is there a harness already for the tach?
thanks guys! </TD></TR></TABLE>
why don't you just get a 90-91 cluster with tach?
Anyways, when these idiots I went to HS with swapped my 91 LX cluster into their 88 std hatch they had to change the plugs as well as speedo sensor stuff.
FastAsleep
Sep 1, 2006 06:41 PM
kizner
Dec 30, 2005 05:44 PM
eumoria
10
Dec 1, 2005 03:07 PM
CalhounBoi
Sep 1, 2005 10:52 PM
Trevor
Aug 1, 2002 10:00 AM
