H22 MPG Question
Old Aug 31, 2008 | 02:25 AM
ahansen's Avatar
Default H22 MPG Question
I own a 2000 Prelude w/ the stock H22A4 & a short ram intake. The car has 114k miles on it. I drive a combination of hwy/city (more hwy than city) & am averaging 32-34 mpg. I drive 10 miles under the speed limit on hwy (55 in a 65), and never rev my engine past 3k rmp's. I started using BP gas w/ invigorate crap. I have only owned this Prelude about 6 months and the previous owner used 5w-30 full synthetic oil. It used a bit of oil (typical H22) and was tired of spending over 6$ every 2 weeks on oil. I contacted the Honda dealer and they said it would not hurt anything to switch to conventional oil, so I switched to Valvoline max life 10w-30 a couple of oil changes ago and noticed a decrease in oil consumption & an increase in gas mileage. I have ran the car up to red line probably 5x's since I've owned it & it seems to pull like it should. Is it actually good for the engine to hit VTEC every once in a while to "clean out the cobwebs?" ? I know it is w/ a turbo car so the waste gate doesn't freeze up and won't boost fully. Also, I have an APEXi world sport cat-back exhaust that I am considering installing. Would the exhaust have an effect on gas mileage? I changed transmission fluid & put in syncromesh. I think that helped a bit. Is there anything else I can do to improve mpg? I do use AC quite often because it's not worth being miserable. Something I would like to do is install a 5th gear from either an F22 or an H23 to reduce rpm's. Any thoughts/suggestions would be great. Don't get me wrong I am VERY happy w/ the mileage I'm currently getting, but I would like to get 35+ if possible. I'm just being greedy. I'm not one of "go green" crazed people. Thanks for the help. BTW my tires are inflated to 45psi (max is 51psi on these tires).
Old Aug 31, 2008 | 05:38 AM
Acidcrakker's Avatar
Default Re: H22 MPG Question (ahansen)
Well for a 5th gen to be getting that type of MPG well, id say that you are one of the luckey ones. Its very good miliage to begin with.
A new muffler wont increase MPG either
Old Aug 31, 2008 | 06:34 AM
E-Money's Avatar
thats great mileage in my opinion... just keep up with your tune ups and your golden. i noticed great increase when changing plugs, flushing out coolant. after oil changes, replacing tires. taking out excess weight in the car.
paarmyguy365
Apr 19, 2010 09:51 AM
easybake323
Mar 10, 2010 02:15 PM
crxsleeper210
Nov 18, 2009 05:23 PM
ahansen
May 2, 2008 09:41 PM
Jeff99Base
Honda Civic (2006 - 2015)
Jan 17, 2008 06:28 AM
