H22 oil prime
I just built my H22 and when I cranked it I got no oil pressure, I primed the oil pump and tried it again and nothing, also I started it for a few seconds and yet again no luck. Im thinking when I primed it the oil just fell right back into the pan. So this is why the priming didnt work. Im really stuck here and I'm looking for some good input.
I did a oil pump on a F series the other day, I cranked it forever with no oil pressure. I started it and still no oil pressure. Cranked it again for a while and it eventually got primed, it took forever but after that it was fine. Keep cranking?
I was told to check the oil gally, it may not be plugged. Would this cause my problem and if so what should I be looking for? (location? pictures?) anything would help.
I cranked this thing for a couple mins. using 10-15 second intervals. The pickup, oil pan look good, no noises coming from the pump. What is the next thing I should do, keep cranking?
I tried to put oil through the hex bolt but it took the rest of the qt I had and it just seemed like it fell straight into the pan so that defeats the purpose, but I just took the oil pickup off and it seemed like the gasket wasn't getting a good seal. I RTV'd it up and im gonna check it tomorrow.
Ok here is an update. The RTV didn't solve the problem
, I filled a bottle with oil and submerged the pickup into the bottle. I cranked the engine for about 30 seconds and it didn't pull any oil. Is this a sign of a bad oil pump or something stupid im missing although it seems like I checked everything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Varano44 »</TD></TR><TR><TD CLASS="quote">What is the proper way to get a prime?</TD></TR></TABLE> you crank the engine for a while. how are you reading that you have no pressure? i mean you could also take the valve cover off and crank it until oil feeds the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Varano44 »</TD></TR><TR><TD CLASS="quote">my pickup isn't sucking any oil up.</TD></TR></TABLE>
and you started and ran this engine with no oil on the journals?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Varano44 »</TD></TR><TR><TD CLASS="quote">Gonna start replacing the pump tonight, and yes I started it, thats what assembly lube is for.</TD></TR></TABLE>
your not getting what im asking. how long did you run it and crank it with out knowing that your engine wasn't getting oil?
Oh my bad, I first cranked it for about 1 min, then I started it for about 15 seconds. Now I have been randomly cranking on it for a good bit of time.
