Major! wiring issue FLUCTUATING GAUGES!!!
Old Aug 30, 2008 | 10:42 PM
dmefb18's Avatar
Default Major! wiring issue FLUCTUATING GAUGES!!!
THIS IS A 91 DA (GS)....OK START AT THE BEGININ... I REPLACED MY GROUND CABLE COMING OFF THE BATTERY, WEEKS LATER THE GAUGES STARTED TO JUMP AROUND, ALL 4...TEMP,RPMS,SPEEDO (which made no sense)and the fuel.... SO AS I WAS DRIVIN ON THE FREEWAY THE PROBLEM STARTED UP AGAIN... AND FINALly FALL TO ITS FACE, TOWED IT BACK TO MY PLACE TO START IT AND ONCE IN A WHILE IT START BUT MOMENTS LATER IT DIES... LIGHTS DONT TURN ON... SPEEDO NEEDLE MELTED OFF... AND WHILE THE PROLEM WAS A ISSUE ON THE FREEWAY BRAKING,TURN SIGNAL, STEREO POWER ON OR OFF, RADAR, ANY LOADS WOULD CAUSE THE GAUGES TO FLUCTUATE....
WHAT I DO KNOW...
BATTERYS GOOD AT FULL HEATLH AND CHARGED
ALL FUSES ARE GOOD
TRIED A DIFFERENT ECU
SOUNDS OF A RELAY TICKING AS I CRANK THE ENGINE(in unisin cranking of the engine and relay ticking)
ALTERNATORS GOOD
STARTERS GOOD
ONLY ? ARE THE RELAYS... WHERE DO I START?
my hunch are the main relay... starter relay possibly... or just a F*$KIN BAD short!
Old Sep 1, 2008 | 01:08 AM
p10hlm's Avatar
Default Re: Major! wiring issue FLUCTUATING GAUGES!!! (dmefb18)
i wanna help you answer your question
BUT YOU KEEP YELLING AT MEEEE
Old Sep 10, 2008 | 04:46 PM
dmefb18's Avatar
problem solved!!!!
Old Sep 14, 2008 | 05:55 PM
lostsonta's Avatar
What did you do to solve your problem?
dmefb18
Jul 17, 2012 09:06 AM
reno96teg
Apr 23, 2008 01:52 PM
keviiinnnnn
Jan 2, 2008 07:27 PM
g-ride-si
Jan 13, 2006 08:14 AM
