Check engine light on...i need help...don't know what's wrong
Old Aug 30, 2008 | 09:31 PM
hondaman_csu_slo's Avatar
Default Check engine light on...i need help...don't know what's wrong
I swapped my ek (96) with a 93 jdm gsr block w/ 97 itr head. I am using an ex 96-98 wiring harness with the obd2 to obd1 jumper to a p28 chipped with jun. My check engine light is on. I don't know what's wrong. Please help
Old Aug 30, 2008 | 09:40 PM
NotNew's Avatar
Default Re: Check engine light on...i need help...don't know what's wrong (hondaman_csu_slo)
you need to ground pin D4 on the ECU, on mine it was a brown wire I just stripp a little insulation off and ran a small wire to a ground. Then your CEL will blink, and you can figure out the code its flashing and it will tell you whats wrong.
Old Aug 30, 2008 | 09:43 PM
Default Re: Check engine light on...i need help...don't know what's wrong (NotNew)
i don't know pin D4 is located. where can i find an electrical diagram for a P28?
Old Aug 30, 2008 | 09:45 PM
NotNew's Avatar
https://honda-tech.com/zerothread?id=1838491
you need to use the search function on this site. TONS of info, I just went through this so i have some links otherwise youd be on your own
Old Sep 1, 2008 | 03:00 AM
thankz
existanzcivicb20
20
May 22, 2017 04:23 PM
n*werk
24
Feb 26, 2009 06:06 AM
[Eg.6]LiLbOy916
Oct 24, 2006 04:38 PM
valentino2k3
Oct 8, 2004 01:08 PM
AgentJam
Aug 11, 2003 02:47 PM
