Power Steering To No Power Steering Swap
Im trying to find a write up on how to swap rack and pinions from Power steering to Non power steering. If some one could point me in the right direction please
Also what model Ef's and Da's came with out power steering ( Donor Car)
Thanks Guys
Thanks Guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohczccrx »</TD></TR><TR><TD CLASS="quote">crx does not have powersteering. but why would you want to convert. alls you have to do is take off the belt and bam no power steering.</TD></TR></TABLE>
auto hatches i know have power steering. and swapping the rack looks alot cleaner.
any manual ef should be swappable. i havent seen write up on it yet.
This is for a friend, and he wants to do it so I told him I would see if H-T had a write up on it. After checking the FAQ I came here.
Your right it does look cleaning hense the reason he wants to do it.
i dont think there is a write up here about it but there is two ways to go about it. You can just take out the pump and all the lines, but you have to loop the lines on the rack with a resivor to keep the rack lubed. Or you can swap out the whole rack. I got my non-power rack out of an std hatch for my sedan. They just bolt right in but you need to get an alignment afterwards.
-jason
-jason
all you need is the manual rack, take out all the PS stuff and put the new manual rack in, for reference it will not work the other way(ps rack in non ps car) because the hole in the crossmember is larger on the ps car. but you should be able to put a non ps rack in the ps crossmember
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">all you need is the manual rack, take out all the PS stuff and put the new manual rack in, for reference it will not work the other way(ps rack in non ps car) because the hole in the crossmember is larger on the ps car. but you should be able to put a non ps rack in the ps crossmember</TD></TR></TABLE>
that is true, i was running the looped setup until i cracked the rear crossmember. i went to the junkyard and got the crossmember and it had a nonpower rack on it so i just swapped it all out and did new outer tierod ends
-jason
-jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef4dr »</TD></TR><TR><TD CLASS="quote">
-jason</TD></TR></TABLE>
Yeah this I think would be the easiest way is to just drop the whole rear cross member and swap in one from a non PS car.
