Aftermarket Cat for smog.
Which aftermarket cat should I buy so I can smog?
I'm sure everyone is gonna say any actual (non test pipe) cat will get me to pass smog as long as my motor is stock and everything is intact. But I've tried to search a few and carsound kept coming up and other misc ones but they are all "high flow" Any companies have direct fit ones that aren't high flow? BTW the car is 95 RS .
Thanks
Thanks
Since you're here in CA, the cat must be CA compliant, and most muffler shops if they are legit, will ask for the sticker or certificate that prooves it's CA compliant if you want them to weld it on.
jefe
14
May 10, 2006 08:03 AM
88turdbucket
Jan 27, 2005 08:58 PM
