1998 GSR Wiring Harness Question - CHECK IT OU!
Old Aug 30, 2008 | 06:50 PM
Mfoehrkolb's Avatar
Default 1998 GSR Wiring Harness Question - CHECK IT OU!
I am going to start off with saying. I did not have my digital camera on me.
Now the good stuff.
Bought this 1998 gsr shell. Had some of the plugs cut to the cabin harness. So i respliced them temporary just to get the car running and what not.
When i was wiring up the plug for the engine harness. All the wires matched up fine. I ran into a problem though.
You can see in the picture provided that 2 wires from the cabin, and 2 wires from the connector are EXACTLY the same.
Solid Blue with 2 Silver Stripes.
I have no clue what they are for and if it okay how i have them. They could be hooked up to the wrong ones but i have no idea.
Someone tell me what this is for and if it even matter's if they were crossed.
Old Aug 30, 2008 | 07:45 PM
Mfoehrkolb's Avatar
Dogginator! I know you have the answer.
Old Aug 30, 2008 | 08:12 PM
roberts88's Avatar
i believe the blue wires are for the rpms. but i could be wrong. idk if that helps at all.
Old Aug 30, 2008 | 08:32 PM
Mfoehrkolb's Avatar
anyone else? i was looking for a wiring diagram but no luck finding anything i need to know.
Old Aug 31, 2008 | 07:27 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
IM not sure what wires they are but can you follow them back to the ECU? then figure out what the pins are?
Old Aug 31, 2008 | 06:26 PM
Mfoehrkolb's Avatar
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">IM not sure what wires they are but can you follow them back to the ECU? then figure out what the pins are?</TD></TR></TABLE>
--- I will have to try that tomorrow morning.
Old Sep 1, 2008 | 07:56 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 1998 GSR Wiring Harness Question - CHECK IT OU! (Mfoehrkolb)
Ge that Helm manual. It will tell you the wire colors. It is going to be a lot of work tracking them.
Old Sep 1, 2008 | 10:08 AM
ironcheftony's Avatar
1 of those blue wires is left open/blank, for the tach signal
Old Sep 1, 2008 | 10:22 AM
Mfoehrkolb's Avatar
Default Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony &raquo;</TD></TR><TR><TD CLASS="quote">1 of those blue wires is left open/blank, for the tach signal</TD></TR></TABLE>
--- Basically. If my tach works. I have them hooked up correctly. If it doesn't work. Swap them.
Old Sep 1, 2008 | 10:40 AM
well no, ur tach is going to work no matter what, its going to recieve a signal off the dizzy, the blue wire should just be tape'd off, i forget what reason its used for, id check my car, but its got a wire tuck so no luck
Old Sep 1, 2008 | 10:22 PM
Mfoehrkolb's Avatar
well.. i got it started today for the first tyime. RPM tach doesnt work at all... idk what is wrong with it.
Old Sep 2, 2008 | 09:40 AM
Mfoehrkolb's Avatar
Bump. What would cause my RPM tach not work at all? What should i look for. how can i diagnose the problem.
Old Sep 3, 2008 | 08:16 AM
Mfoehrkolb's Avatar
Anyone know how i would diagnose this rpm problem?
Old Sep 4, 2008 | 04:22 PM
Mfoehrkolb's Avatar
Old Sep 4, 2008 | 06:17 PM
what kind of harness and distributor are u using
Old Sep 4, 2008 | 09:04 PM
Mfoehrkolb's Avatar
OBD2 LS distributor (1leg cut off) original obd2a cabin harness and a p73 engine harness with some of the plugs i needed spliced in.
Old Sep 8, 2008 | 09:09 PM
Mfoehrkolb's Avatar
still isn't working. can someone help me out and tell me why my rpm rach isn't working/
Old Sep 9, 2008 | 01:32 AM
IN VTEC's Avatar
Default Re: (Mfoehrkolb)
The tach wire runs from the distributor into the driver-side connector. You'll have to use the service manual or ETM to figure out which pin number it's set into. It's not hard, all you have to use is your brain.
Old Sep 9, 2008 | 08:17 AM
Mfoehrkolb's Avatar
Default Re: (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">The tach wire runs from the distributor into the driver-side connector. You'll have to use the service manual or ETM to figure out which pin number it's set into. It's not hard, all you have to use is your brain.</TD></TR></TABLE>
--- So it is as simple as ...
distributor
to
female connector (distributor connector)
to
male connector (engine harness connector)
to
some wire (wireloomed stuff)
to
to female connector (engine harness connector)
to
male connector (cabin harness in engine bay)
to
cabin harness (cluster/ecu)
Old Sep 9, 2008 | 12:59 PM
IN VTEC's Avatar
Pretty much. Just find the solid blue wire on the engine harness and jump across the terminal. Then make sure it's paired with the correct wire or that it has continuity with the RPM wire for the ECU and dash gauge.
Old Sep 9, 2008 | 04:16 PM
Mfoehrkolb's Avatar
ill check it out next time i stop at the garage. that's something i gotta fix asap.
Since i am using a ls distributor, i am guessing that's where my problem lies originally.
Old Sep 10, 2008 | 11:08 PM
Mfoehrkolb's Avatar
[b]CONNECTOR FROM DISTRIBUTOR
[b]ENGINE HARNESS TO DISTRIBUTOR
[b]ENGINE HARNESS TO CABIN HARNESS
[b]CABIN HARNESS TO ENGINE HARNESS
[i]I didn't see you say follow the solid blue wire... That's the reasoning behind taking these pictures. So basically. I gotta follow that blue wire de-pin it and re-pin it into the corresponding cabin harness blue/silver stripped wire. Bah, i wish i would have seen you say solid blue. I could have tried it out earlier.
slams2k
Honda S2000
Jun 6, 2008 03:52 PM
rioninja
Oct 15, 2005 01:23 PM
gezer
Aug 28, 2004 11:33 PM
mstewar
Dec 18, 2003 08:26 AM
