96 civic ex charging problems
have 2nd new battery and have good (tested) alt. but at idle or 2000 rpm i am only getting 12.5 volts at alt. test voltage at 4 wire plug with key on engine off and got...
white/red=5.2 volts
white/green=.5 volt
black/yellow=12.5
white/blue=12.5
also checked out the alt sp sensor fuse number 15 and it is fine i dont get a battery light or chargin light on the dash only sign i get of charging problem in batteries dying and when hook up volt meter it only shows 12.6 volts running need any help thanks
white/red=5.2 volts
white/green=.5 volt
black/yellow=12.5
white/blue=12.5
Darkveldrin
Feb 26, 2014 07:12 PM
lunaticfringe74
Jan 15, 2009 05:17 PM
