B series VS D series Pros & Cons of both.
Old Aug 30, 2008 | 04:23 PM
crxrider07's Avatar
Default B series VS D series Pros & Cons of both.
I am just trying start a good topic while learning some stuff at the same time. thanx for input!
Old Aug 30, 2008 | 04:33 PM
dlaub25's Avatar
Default Re: B series VS D series Pros & Cons of both. (crxrider07)
Well one thing I was surprised at when I went to the B16 from a D series was there was no noticeable change in gas mileage. However, I'm sure if I had gone from a D15 to a B18 I would have seen a difference. Of course the B series engines are available in a 1.8 liter version, and there is the fact that <U>most</U> of the D series engines are SOHC. DOHC to me means smoother top end and more potential in terms of valve timing (this is my opinion). Most people say that the B series just has more "potential", while that may be true I feel the "potential" of the D series is under rated.
Old Aug 30, 2008 | 04:37 PM
crxrider07's Avatar
I personaly love the b series motors, when you turbo them they come alive and produce real power. i am currently buiding a d16 cuz its so cheap and i only am tryin to build a reliable 230whp turbo daily driver. (turbo, reliable, yeah right!) but i leaning more in favor of the B series.
Old Aug 30, 2008 | 04:39 PM
crxrider07's Avatar
Default Re: B series VS D series Pros & Cons of both. (dlaub25)
you said it better
Old Sep 3, 2008 | 10:50 AM
JDM-JAMES's Avatar
d series cheap
400+ on stock sleeves
vitara pistons hold 450+hp and only cost 120
loads of torque
b series beefy
it can make loads of power
more displacement
and im going d-series since people think the more cams you have the more power. and i can have a built bottom end for less than 300
only if d-series had a shorter stroke and a bigger bore it could make close to the same power as b series with one less cam.
Old Sep 3, 2008 | 01:15 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: (JDM-JAMES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-JAMES &raquo;</TD></TR><TR><TD CLASS="quote">d series cheap
loads of torque
b series beefy
more displacement
B heads flow a gabillion times better then the d counterparts. Sorry. And you pulled that 400 and 450 hp number out of your ***.... their stock rods are horseshit.
<FONT SIZE="20">SEARCH MY CHILD</FONT>
Old Sep 3, 2008 | 02:50 PM
Radim's Avatar
Default Re: (ComeOnKip)
Timing Belt snaps on your B16, you'll end up wishing you stayed with a D16
Old Sep 3, 2008 | 03:02 PM
grog's Avatar
Default Re: (Radim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radim &raquo;</TD></TR><TR><TD CLASS="quote">Timing Belt snaps on your B16, you'll end up wishing you stayed with a D16</TD></TR></TABLE>
I though they are both interference engines, meaning your valves will most likely get bent when the timing belt snaps.
and a D series being able to take 400 hp + on stock sleeves reliably is
Modified by grog at 7:55 PM 9/3/2008
Old Sep 3, 2008 | 03:05 PM
SmellsLikeMustand's Avatar
umm d16 for gas mileage.
k series for smacking v8's!
Old Sep 3, 2008 | 03:07 PM
SlipGear's Avatar
Default Re: (Radim)
Thats why you do routine maintenance B-Series FTW
Old Sep 3, 2008 | 05:28 PM
hondaluver12's Avatar
Default Re: (SlipGear)
Kinda in this thread... im boring out my SOHC ZC non v-tec 30 over. Going to use a 6-puck clutch, and doing a mini-me swap. what kinda power can i expect?
Old Sep 3, 2008 | 05:42 PM
de1991hatch's Avatar
Default Re: (hondaluver12)
You can slam a d-series B-series... not so much.
Old Sep 3, 2008 | 05:46 PM
Radim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaluver12 &raquo;</TD></TR><TR><TD CLASS="quote">Kinda in this thread... im boring out my SOHC ZC non v-tec 30 over. Going to use a 6-puck clutch, and doing a mini-me swap. what kinda power can i expect?</TD></TR></TABLE>
Probably around 130ish.
Old Sep 3, 2008 | 05:55 PM
JOE BD-0's Avatar
If you want a b series motor in an ef, you also need to buy mounts ......
Old Sep 3, 2008 | 06:01 PM
D16SiHatch's Avatar
Default Re: B series VS D series Pros & Cons of both. (JOE BD-0)
after going to a b18b from an a6/y8 setup i will never go back. its so much quicker, and it has a lot more low rpm grunt for just tooling around town under 3000rpm. i think next ill be goin with a sir II b16a
Old Sep 3, 2008 | 06:18 PM
661rex89si's Avatar
Default Re: (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">
and a D series being able to take 400 hp + on stock sleeves is </TD></TR></TABLE>
its been done many times already you moron why dont you search and with no block guard lol. hell it even ran 10's
it amazes me how much people underestimate the D. if your destined to go B start of with the b18a/b swap cause they don't disappoint like the b16. this is coming from experience.
Old Sep 3, 2008 | 06:51 PM
grog's Avatar
Default Re: (661rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661rex89si &raquo;</TD></TR><TR><TD CLASS="quote">
it amazes me how much people underestimate the D. if your destined to go B start of with the b18a/b swap cause they don't disappoint like the b16. this is coming from experience.</TD></TR></TABLE>
I dont doubt the numbers I just doubt the reliability, moron
Old Sep 3, 2008 | 07:10 PM
661rex89si's Avatar
Default Re: (grog)
I dont doubt the numbers I just doubt the reliability, moron </TD></TR></TABLE>
its been over a year now moron lmao. come on keep it coming
Old Sep 3, 2008 | 07:22 PM
vtecb18c's Avatar
lol...grog the d series has seen well over 350hp boosted without touching the sleeves...the rods are the weakest part of the d series, the block is pretty strong
Old Sep 3, 2008 | 07:24 PM
IntegraLova's Avatar
Default Re: (grog)
Modified by grog at 7:55 PM 9/3/2008</TD></TR></TABLE>
Well if your d16 head gets ruined, you can find a replacement for next to nothing. Getting a replacement b16 head on the other hand..........not so cheap.
Old Sep 3, 2008 | 07:31 PM
dohczccrx's Avatar
Default Re: (vtecb18c)
d-series for the win. dohc zc=1.6L 130-140hp and b18a1/b18b1=1.8L 120-140hp
d-series=400hp with $500 bottom end
b-series=400hp with $800 bottom end, plus the cost of the swap
d-series=direct swap
b-series=axles,harness,mounts,ecu,ect.....
Old Sep 3, 2008 | 07:36 PM
vtecb18c's Avatar
Default Re: (dohczccrx)
ummm...hmmmm....i've seen boosted b16s and gsr's make almost 500hp on a stock block so i dont know where your trying to go with your post..yea the swap may cost you more money but its def worth it
Old Sep 3, 2008 | 07:40 PM
dohczccrx's Avatar
well i dont think there is any point in arguing opinions. and especially ones that are from just hear say
Old Sep 3, 2008 | 07:47 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohczccrx &raquo;</TD></TR><TR><TD CLASS="quote">well i dont think there is any point in arguing opinions. and especially ones that are from just hear say</TD></TR></TABLE>
Its all fanboi bullshit out of both camps. There is no end to * vs * in the honda world.
It all comes down to your goals and how much you can spend.
K&gt;B&gt;D.......thats just the way it goes.
Old Sep 3, 2008 | 07:50 PM
dohczccrx's Avatar
Default Re: (SIred91)
i think you meant D&gt;H&gt;B&gt;F&gt;J&gt;A&gt;C&gt;G&gt;L&gt;N&gt; R&gt;E&gt;k
