my back lights wont go off =[
Old Aug 30, 2008 | 03:55 PM
LsTegDriver's Avatar
Default my back lights wont go off =[
can somone please let me know and if possible
make a noob friendly walk through on how to
fix this problem??
cause even when the car is turned off its like the cars back light
is on forever brake light im sure of it
Old Aug 30, 2008 | 07:20 PM
Circusraven's Avatar
Default Re: my back lights wont go off =[ (LsTegDriver)
Ummmm it's probably the back up sensor on the tranny that's stuck somewhere. Try to wiggle em' around (very technical I know ). They are the cables in front of the tranny, you can't miss them.
Old Aug 31, 2008 | 05:40 PM
Dogginator's Avatar
Daisy... Daisy...
When you ask a question like this, you should specify which car (model, year, transmission, etc.).
There is a reverse light switch on the transmission as in the following diagram for a 2001 GSR (Part 10). Disconnect the plug for the switch and see if the lights turn off. If they do, the switch is at fault.
Old Sep 1, 2008 | 01:04 AM
ironcheftony's Avatar
mmm red brake lights i think you are refering to
on you brake pedal, the very top, there is a push button style switch that the lever hits to stop the lights, on that lever is fitted a rubber/plastic gourmet that pushes teh button, some reason its missing, u can replace it with a 10mm nut and bolt or something of that nature, good luck
josephb
Jul 31, 2011 01:16 PM
neogenesis2004
Mar 3, 2009 04:21 PM
dailyteg
Aug 15, 2007 04:49 PM
crxtreme27
Apr 20, 2003 01:37 PM
