check engine light on.. b16a in crx ... need help!
Old Aug 30, 2008 | 03:07 PM
pearsonhondatech's Avatar
Default check engine light on.. b16a in crx ... need help!
i have an 88 crx with a b16a.. after starting it idles at 3,000 rpms and the check engine light is sayin code 4 .. map sensor, i replaced it with a good map sensor and still having the same problems... also when i go to accelerate it bogs out and looses any and all power. i really want to get this thing running asap so any help would be great, thanks
Old Aug 30, 2008 | 03:26 PM
davesrex's Avatar
Default Re: check engine light on.. b16a in crx ... need help! (pearsonhondatech)
Are you sure you have all your vacuum lines run to the proper ports. Are there any cracks in the vacuum lines?
Old Aug 30, 2008 | 03:50 PM
Default Re: check engine light on.. b16a in crx ... need help! (davesrex)
no i do have vaccume leaks i need a pic or sumthin for where they go.. i have a usdm intake manifold and throttle body on my jdm b16.. please help
Old Aug 30, 2008 | 07:48 PM
jlicrx's Avatar
code 4 is not MAP sensor - it is the Crank circuit in the distributor - usually means you need a new distributor, unless it isn't wired up right - if this is a new swap and the code 4 has always been there, try switching the orange and white wires at the distributor and see if that fixes it - otherwise, you probably need a distributor
Old Aug 30, 2008 | 10:02 PM
Default Re: check engine light on.. b16a in crx ... need help! (jlicrx)
ok.. well this is the 2nd b16 in the crx.. with the first one the dizzy went bad and i got a brand new dizzy and about a month later i blew the motor. well swapped another b16 in it and drove fine for about 2 months then blew a fuel line started bogging out.. it is a brand new dizzy and i still have vaccume leaks out the *** (so still any pic or help with vaccume hose placements would be good). please help .. trying to get this thing running good.
Old Aug 31, 2008 | 07:42 AM
davesrex's Avatar
This is all that i can find, its for the 90 integra with a b18a1, but it might get you closer. My b16 is sitting on my garage floor or else i would take some pics of that.
http://alldatapro.com/alldata/...57543
Modified by davesrex at 8:49 AM 8/31/2008
Modified by davesrex at 8:50 AM 8/31/2008
Old Aug 31, 2008 | 07:58 AM
davesrex's Avatar
Here is another that i found online for the b16
http://www.geocities.com/jopivym/motor.htm
Old Aug 31, 2008 | 08:00 AM
davesrex's Avatar
And once you get that done here is a link to diagnose your code 4. http://alldatapro.com/alldata/...50555
pearsonhondatech
Apr 12, 2009 09:54 PM
i_VTEC
17
Oct 15, 2007 10:17 AM
vw eater
Jan 4, 2007 04:45 PM
Gamble-Did-it
May 30, 2004 06:42 PM
