ls/vtec turbo question
hey everyone i just purchased a 97 ek ls/vtec turbo here is the link to what it has if it helps answer my question http://drenicacustomsauto.com/dca2.html
the idle lopes and i was wondering if it was from having the ITR cams...Should I get different cams thats more geared towards boost like the skunk2 turbo 2 cams? Also should i get smaller injectors? My gas milage is horrible Not even touching boost levels. Kind of depressed because i had it on the dyno at only 7lbs and it made 177 at the wheels if you guys have any suggestions about my set up please lemme know. Please save your negative comments for someone else thanks
