XENON HID OVERSTOCK BLOWOUT ! ! ! ONLY $150 SHIPPED
Former Sponsor - Cancelled
We are proud to announce that Koyo Industries has recently merged with CRG Motorsports LLC. Our goal is to provide Honda Tech members with the best service and price possible.
3000K Golden Yellow HID Conversion Kit
5000K Crystal White HID Conversion Kit
6000K Crystal Blue HID Conversion Kit
8000K Blue/Purple HID Conversion Kit
10000K Deep Blue HID Conversion Kit
12000K Violet Purple HID Conversion Kit
<U>Applications:</U>
• H1
• H3
• H4
• H7
• H8
• H9
• H10
• H11
• H13
• 880
• 9003
• 9004
• 9005
• 9006
• 9007
• D2S
• D2R
<U>Description:</U>
HID stands for High Intensity Discharge. It refers to lighting technology that relies on an electrical charge to ignite xenon gas contained in a sealed bulb. One great advantage of HID lighting is that it doesn't have a filament but instead creates light by igniting an arc between two electrodes. HID lights get their name from the intense white light produced by the electrical discharge. Halogen bulb which has filament has a lifespan of about 250 hours (1 year) , HID bulbs are gas filled capsules that are rated for a life of 2500-3000 hours (3 to 5 years). Another fact is that they use only 35 watts of electricity, while your stock Halogen bulbs requires 55 watts.
<U>Xenon-Vision Waterproof Ballast:</U>
Xenon-Vision ballasts are the most reliable and resilient of all the ballasts in the market, but also have a lower wattage requirements than others. If you purchase a kit with a separate igniter box, it does not have the strength or durability of our Xenon-Vision ballast. Not only they take up more room in your engine bay but are prone to burn outs, surges, and just start dying out of nowhere. Xenon-Vision ballast is not only shock-proof but it is also waterproof as well. We are so confident about our product, we put our ballast to the test by submerging the ballast in water while it is on. Our Ballast are backed by a replacement warranty of 1 year after purchase.
<U>HID Bulbs:</U>
HID lights get their name from the intense white light produced by electrical discharge. HID lamps are also called xenon lamps referring to a gas inside the lamps. HID Lights are currently used in most sports arenas, stadiums and trains around the world. Don't be fooled by the Xenon Bulbs that sell for $20 at any retail shop. They produce a very scattered and artificial light that are less bright than normal halogens. They are no match for the intensity, purity, and efficiency of High Intensity Discharge Headlights.
<U>Features</U>
•True Play-N-Play Conversion Kit
•Brighter driving vision at night
•3 times brighter than halogen bulbs
•Fits into existing headlights or fog lights, no modification or retrofitting required
•Nice color output with a hint of blue or purple (6000K Kit and higher)
•35W power consumption compare to 55W halogen bulbs
•Bulb Lifespan of 3 to 5 years
•ISO9001 Certification and European E-Mark for 100% guaranteed product quality
•Ballast has shut off mode, to prevent a fire or damages if a glitch occurred.
•Ballast and Bulbs is Waterproof and Shockproof
•Waterproof connectors and grommets
•1 year warranty on bulbs and ballast
<U>Specifications</U>
[B]Xenon-Vision Waterproof Ballast
<U>Items Specifications Conditions</U>
•Efficiency > 95% 13.5V nominal input voltage
•Starting Input Voltage 12.8V
•Operating Input Voltage 9~16V
•Nominal Input Current 3.5A 13.5V nominal input voltage
•Minimum Protection voltage 6V
•Maximum Protection voltage 18V
•Nominal Lamp Voltage 85V
•Open Circuit Voltage 400V
•Ignition Lamp Voltage 23kV
•Inverter Frequency 400Hz
•Ripple Voltage < 5V
•Lamp-Open Circuit Operation Shutdown Mode
•Lamp-Short Circuit Operation Shutdown Mode
•Light Stabilization Time 4 Sec
•Special Features Water Proof & Shock Resistant
<U>HID Bulbs</U>
<U>Items Specifications </U>
•Luminous Flux 1,800 (± 200) lm
•Lamp Life 2,500 - 3,000 hours
•Color Temperature 12,000 (± 300) K
•Lamp Voltage 85 (± 17) V
•Electrodes 4.2mm arc length
•High Voltage Wire 20kV Silicone 3.4SQMM
•Low Voltage Wire 10kV Silicone 2.8SQMM
•Power Wire AVSS 2SQMM
•High Voltage Connector Waterproof Connector
•Low Voltage Connector Waterproof Connector
•Power Connector Waterproof Connector
•Grommet High Temperature Silicone
Note: The higher the Kelvin (K) rating, the more blue or purple the light output will be. As the K rating goes up, light output goes down. We recommend HID kits ranging 5000K to 8000K.
<U>Warranty:</U>
Warranty Coverage on bulbs and ballast
Bulbs and Ballast are warranted for a period of one (1) year from the date of the purchase. Warranty does not cover breakage due to improper installation, shipping or handling.
<U>Exclusions:</U>
Any defects resulting from water damage, fire, acts of nature, misuse, abuse, modification, improper installation, vehicle crash, or any type of impact. Any modification to the system or operating on a vehicle with a damaged headlight housing, will void the warranty. Xenon-Vision will not be responsible for damages to automobiles resulting from the use, misuse, or inability to use a Xenon-Vision product.
<U>Installation</U>
Xenon-Vision HID Conversion Kit is a True Plug-N-Play Kit. Our conversion kits fit into your headlight housing perfectly. No modification or retrofitting is required. No need to cut your stock headlight wiring. Our kits is made so that it all Plug-N-Play.
Just connect the wiring harness from the stock headlight wiring to the ballast. From the ballast, connect the wiring harness from the ballast to the HID Bulbs. Put the HID Bulb back into your headlight housing and your done. Detailed instructions will be included in the kit. Please use the bulb replacement guide to find out what bulb size your car uses.
<U>PAYMENTS ACCEPTED:</U>
PAYPAL: info@getcrg.com(Please add 3.3%)
CREDIT CARD: VISA, MASTERCARD, DISCOVER
CHECK/MONEY ORDER:
MAKE PAYABLE TO:
Koyo Automotive
1224 S. GARFIELD AVE SUITE D
ALHAMBRA, CA 91801
P:626.400.8040
http://www.getcrg.com
***PLEASE BUMP IF YOU VIEW***
Modified by koyo-industries.com at 4:01 PM 8/30/2008
