For all u Koni Yellow and Ground control Peopl
Old Aug 30, 2008 | 08:47 AM
omarisramo's Avatar
Default For all u Koni Yellow and Ground control Peopl
hey guys, just put on some Koni Yellows along with Ground Controls.
problem is the front sits really well but the back seems to look "stock"
what can i do for it to be dropped like the front
95 accord lx
Old Aug 30, 2008 | 08:51 AM
TheMuffinMan's Avatar
He knows where you live!
Which perch did you use on the Koni's?
What spring rate did you use? Did you put the 350's in the back or the front?
How low are the GC's?
Old Aug 30, 2008 | 09:04 AM
omarisramo's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">Which perch did you use on the Koni's?
How low are the GC's?</TD></TR></TABLE>
im pretty sure, there both on the lowest perch, and the fronts are suppose to be in the front along with the backs
Old Aug 30, 2008 | 09:13 AM
Your spring rates should be 350/250 (f/r)
Just shine a flashlight in there and take a look , should be written on the springs. That'll verify you have that correct.
My other guess is your rears are not seating properly in the top hat, take a look at that as well.
Did you install a camber kit by any chance? That could cause the upper arm to clear. (Happened to me in the front)
Old Aug 30, 2008 | 09:25 AM
omarisramo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">Your spring rates should be 350/250 (f/r)
Did you install a camber kit by any chance? That could cause the upper arm to clear. (Happened to me in the front)</TD></TR></TABLE>
i dont have a camber kit installed on it.
i'll take a look asap! and let u know
Old Aug 30, 2008 | 09:26 AM
If you have 350's in the rear it should still be lowered down, that's what I have in my rear. Something is not seating properly.
Old Aug 30, 2008 | 05:34 PM
Cannon Man's Avatar
Sounds like the perch. I put mine on backwards and it looked stock
foohz
Suspension & Brakes
171
Feb 28, 2013 03:22 PM
datssoled
Suspension & Brakes
Aug 17, 2009 01:25 PM
FastLife617
Suspension & Brakes
Mar 5, 2008 07:11 PM
Asselin
Aug 18, 2005 04:42 PM
PatrickGSR94
Jun 13, 2004 07:19 PM
