99-00 OEM civic RETROFIT - Mercedes E55 BiXenon Retrofit = Nice !
Snipper Snapper
Info on the 99-00 Si Retrofitted Headlights :
Includes:
-Mercedes E55 Bi-Xenon Projectors modified for more color
-Hella Ballasts
-Hella Ignitors
-D2S bulbs
-Custom Wiring w/ Fuses
-OEM headlight housings from 00 Civic SI
-Custom Shrouds
The inluded wiring harness is made to be run straight from the battery with inline fuses included. You have to simply ground each ballast when you mount them, ground one terminal on the relay and hook the other terminal on the relay up to the headlight switch. Wiring for the high beams is not included but it is fairly easy to hook up. Each projector has two wires which activate the high beam when 12v is applied. The lights are in great condition.
Price: $550
Here are the pictures finally... very sorry about the wait !
They are all packaged up for a buyer !
Thanks guys
Includes:
-Hella Ballasts
-Hella Ignitors
-D2S bulbs
-Custom Shrouds
Price: $550
Thanks guys
