obd0 b16a no spark!!!!!! help
Old Aug 30, 2008 | 05:49 AM
jeremiah963's Avatar
Default obd0 b16a no spark!!!!!! help
so i was driving last night and my car just died on me..... it was driving fine but then is lost all power and back fired!!!!! today i checked the dizzy cap and rotor to find that the rotor was in peaces inside the dizzy cap so i replaced that.... still nothing.... changed the whole dizzy with a known working dizzy nothing.... checked timing at the cam gears and they look to be right.. all grounds are good... pulled the spark plugs out and they were black so i know its getting fuel... also i can smell fuel... ive tryed switching out to a stock pr3 ECU and still no spark... i have also changed out the main relay..any other ideas.... please let me know this is my DD
Old Aug 30, 2008 | 07:34 AM
CRXSI_09's Avatar
Default Re: obd0 b16a no spark!!!!!! help (jeremiah963)
Have you checked the ecu fuse under the hood? That looks like the only thing you haven't checked.
Old Aug 30, 2008 | 04:26 PM
Default Re: obd0 b16a no spark!!!!!! help (CRXSI_09)
yes i have checked all the fuses under the hood and under the dash
Old Aug 30, 2008 | 04:39 PM
915hondajunkee's Avatar
I had the same problem with my rex...turnes out to be a bad coil and igniter inthe distrubutor... check for resistance...they supply your saprk if its not he coil.. thenits the igniter...
Old Aug 30, 2008 | 04:43 PM
Hercules's Avatar
I would try yet another distributor just to triple check. Maybe a coincidence the known working dizzy went bad also.
Old Aug 30, 2008 | 04:47 PM
Default Re: obd0 b16a no spark!!!!!! help (Hercules)
just try the coil first.. still no spark then the igniter.. so you dont have to keep changing "dizzys" as you call them... i bet its one the the two to blame....
Old Aug 30, 2008 | 04:57 PM
Hercules's Avatar
Default Re: obd0 b16a no spark!!!!!! help (915hondajunkee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 915hondajunkee &raquo;</TD></TR><TR><TD CLASS="quote">just try the coil first.. still no spark then the igniter.. so you dont have to keep changing "dizzys" as you call them... i bet its one the the two to blame....</TD></TR></TABLE>
He most likely doesnt have a good coil and igniter lying around. I meant it would probably be much easier to borrow a friends dizzy (just an abreviation), to see if thats the problem.
If the 3rd dizzy has spark then he can go and purchase a new dizzy or coil/igniter.
Not trying to be an a-hole just wanted to make myself clear.
Old Aug 31, 2008 | 12:52 PM
even if you dont have a coil or igniter lying around the fastest and easiest way is to check for resistance in the coil and igniter... ohm them out its very simple...ohms LAW....es 101 electrical basics........
Old Aug 31, 2008 | 02:26 PM
switched out spark plugs today and still no spark.... im getting power to the dizzy.... gettin power to the coil but theres no power coming out... put in a new coil and ignitor.... still no spark... so i got curious and took my old dizzy apart to find that it is locked up and will not turn at all...... i started checking cam to crank timing to find that its about 2 -3 teath off... so i am going to put it back in time and hope for the best..
Old Sep 1, 2008 | 04:30 PM
put it back in time still no spark
Old Sep 2, 2008 | 03:38 PM
ttt
PreludeAddict
Jun 24, 2014 08:53 PM
JDM_EK_wanabe
Oct 19, 2009 09:01 AM
jeremiah963
Sep 2, 2008 11:29 AM
racerboyb18c1
Nov 18, 2003 07:46 PM
2k1_ITR_0736
17
Jan 26, 2003 04:09 PM
