Seaibon carbon fiber hood, valver cover clearance problems.
Old Aug 29, 2008 | 11:01 PM
no1knows908's Avatar
Default Seaibon carbon fiber hood, valver cover clearance problems.
I bought and installed an OEM style Seibon carbon fiber hood a few weeks ago on my 4th gen H22A. I recently noticed that the under skeleton of the hood is rubbing against the valve cover in a few areas. I would expect this from a cheaper brand but not Seibon. I was just curious as to if anyone else had problems similar to this. Also would it be better to add washers to the hing, or should I raise the latch? Also I am running ESP polyurethane motor mounts, not sure if that would cause the engine to sit slightly higher or not.
Old Aug 30, 2008 | 06:04 AM
avbrachbum1989's Avatar
Default Re: Seaibon carbon fiber hood, valver cover clearance problems. (no1knows908)
how much you selling the kit for?
Old Aug 30, 2008 | 06:22 AM
Apex1972's Avatar
Do you have another hood you can try in its place to see if it rubs too?I doubt it would be a mount issue. Never heard of this happening on a 4th gen b4.
Old Aug 30, 2008 | 07:35 AM
Sir Kyle's Avatar
Default Re: Seaibon carbon fiber hood, valver cover clearance problems. (Apex1972)
I had the same problem on my 5th gen with a VIS hood. I'm trying to find some of that hood insulating foam to put on the underside. I think that might work....for a while.
Old Aug 30, 2008 | 08:34 AM
G2IntegraGS's Avatar
Im running a seibon on my 4th gen with H22 and Innovative mounts. No rub issues that Im aware of. You might want to try rasing the latch a hair and maybe adding some small washers to the back. I would do both, not one or the other.
Old Sep 2, 2008 | 02:13 PM
Default Re: Seaibon carbon fiber hood, valver cover clearance problems. (G2IntegraGS)
Sorry guys, I've been stuck in Baton Rouge, LA with no power so I haven't had time to reply. The factory hood fit perfectly with no problems. It does look like the front of the hood does sit a little low near the latch so I will raise it slightly and see if the rubbing continues.
Old Sep 2, 2008 | 04:03 PM
MJOLNIRvTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS &raquo;</TD></TR><TR><TD CLASS="quote">Im running a seibon on my 4th gen with H22 and Innovative mounts. No rub issues that Im aware of. You might want to try rasing the latch a hair and maybe adding some small washers to the back. I would do both, not one or the other.</TD></TR></TABLE>
that should take care of it, ive heard of random issues such as yours with any aftermarket hood oem or not. it so bizarre, but it happens. give it a try and let us know if it helped
Old Sep 2, 2008 | 04:20 PM
Default Re: Seaibon carbon fiber hood, valver cover clearance problems. (MJOLNIRvTEC)
Here's some pictures of the current hood latch height. have not done any adjusting yet, but do you think the hood latch height is the culprit?
Old Sep 2, 2008 | 04:57 PM
lude98SH's Avatar
i have no clearence problems with my seibon on my 5th gen.
Old Sep 2, 2008 | 07:18 PM
Default Re: Seaibon carbon fiber hood, valver cover clearance problems. (lude98SH)
Can someone please compare my hood gap to their factory hood so I don't have to put mine back on?
Old Sep 3, 2008 | 08:15 AM
snobordboy's Avatar
Moderator
I will say that Seibon probably has very tight clearance in that area, my Seibon is a vented hood, and came with a undertray for blocking the vents, which rubbed on the valve cover on the H22 as well, but I have enough clearance without that tray in. Sucks since I need the tray for rain/ snow, but I lost it and can't find a new one.
I would say to raise your latch a bit though, it looks very close in the middle, and I would set it so the visible gap is the same from hood-headlights as hood-bumper center. If that doesn't cure it, maybe raise the back of the hood a tad with washers?
gogunkergorilla
May 28, 2007 08:28 PM
Lewdin' Incognito
Aug 22, 2005 07:25 AM
Cowboy
Feb 6, 2002 08:33 AM
Cowboy
Jan 30, 2002 08:39 AM
Cowboy
Jan 28, 2002 06:10 PM
