Need help my hatchback wont start!!!
Old Aug 29, 2008 | 06:53 PM
hyrev20's Avatar
Default Need help my hatchback wont start!!!
All right lets get started i have a 91 honda hatchback std when i try to start my car i would hear a click sound coming from behind my cd player and when i check it.....it was my relay that is behind there. Is that the problem for my car from not starting....Dam!!! please help me out.
Old Aug 29, 2008 | 07:13 PM
Ermil's Avatar
Default Re: Need help my hatchback wont start!!! (hyrev20)
Have you done any diagnosis? Is the battery fully charged? Is the starter engaging?
Old Aug 29, 2008 | 07:33 PM
onefastek9's Avatar
need more info dude, what relay? like ermil said have you done a diagnosis yet and so fort?
Old Aug 30, 2008 | 12:50 AM
hammergunner's Avatar
Default Re: (onefastek9)
ok, does you motor even turn over?
if not check the starter as one of the wires may have come loose, as this happens alot on older civic.
Old Aug 30, 2008 | 05:53 AM
hyrev20's Avatar
Well i will go check the starter and the others. But in the mean while heres the part number of the relay that is just clickin when i try to start it RELAY ASSY., POWER (4P) (056700-9410) (DENSO)
Old Aug 30, 2008 | 05:54 AM
hyrev20's Avatar
Oh the motor dont turn it just click on a relay its hella wired
Old Aug 30, 2008 | 07:53 AM
CRXSI_09's Avatar
Default Re: (hyrev20)
I just looked up the relay your asking about. Thats for the cigarette lighter. I don't think thats your problem. Check the starter.
Old Aug 30, 2008 | 06:27 PM
hyrev20's Avatar
Default Re: (CRXSI_09)
Aight i will check the starter......bro and i will let you know if thats the problem bro
Old Aug 31, 2008 | 05:46 PM
hyrev20's Avatar
its not the stater i take it to autozone and test it out and it didnt fail. Man i dont know already just dont know what it could be it was running strong and stuff and it just stop freakin need help for real....
Old Sep 1, 2008 | 02:47 AM
japanstar_ef9's Avatar
my 91 hatch is doing the exact same thing.It was running strong i put the complete msd system and it was fine then 2 days after i go to start it and it just clicks,its not turning over, not even trying to,battery is fully charged,i changed starters and it still does not work. the only way for my car to run is to pop start it and then it will run strong how it use to until i turn it off. as soon as i turn it off i try to start it and same thing. lemme know if you figure anything out please.
Old Sep 1, 2008 | 09:53 AM
hyrev20's Avatar
Default Re: (japanstar_ef9)
Yeah i will let you what happens i try change it to a new battery and my battery fuse blow out man now i am getting crazy with this but yeah when i find out what it is i will hit you up i may pm you aight laters....
Old Sep 1, 2008 | 10:43 AM
Jet805's Avatar
does you care actually have power though? IE dash lights come when the key is in the on position? Does the beeping noise from the seat belts sound weaker when you try starting it?
I'm with whoever is saying its a battery problem. They can check that at napa / autozone to. Or just try to jump your car and see if it starts and if it dies get a new batt or look for a draw.
Old Sep 1, 2008 | 11:56 AM
Bonestock98GS's Avatar
Default Re: (Jet805)
If you said it keeps popping fuses then someone correct me if I am wrong you might have something grounded that isnt supposed to grounded. That causes the main link to pop and main link causes nothing to come on. that happened to me a few weekends ago
Old Sep 2, 2008 | 10:45 PM
ALLxMotor DA's Avatar
Default Re: (Bonestock98GS)
I agree with bonestock98gs check your ground wires.
Old Sep 2, 2008 | 10:56 PM
you might have burnt your ignition, get one from a junk yard, plug it in and turn to check
also, right a wire from the - of the starter and ground it out on the body , if it starts, then that means you burnt a starter wire some where, i've taking apart a whole si harness and dx harness, theres on 2 wires for the starter, 1 going to the battery, the other to the starter itself
Old Sep 2, 2008 | 11:05 PM
sanegb16's Avatar
Default Re: (hammergunner)
Did you check the main relay? the solder on goes bad and makes stuff go bad.
Old Sep 2, 2008 | 11:51 PM
SingleCamin's Avatar
SAME PROBLEM !?..WHEN I TURN KEY IGNITION IT WONT START.. ONLY PUSH START WORKS !!! anybody !?? need help
Old Sep 3, 2008 | 05:08 AM
grkblood13's Avatar
check and see if the pedal pads are there. they might have broken off.
Old Sep 3, 2008 | 09:49 AM
Default Re: (grkblood13)
OO i did i think it ripped off or it went threw the car HI hater
Old Sep 3, 2008 | 10:35 AM
grkblood13's Avatar
Default Re: (SingleCamin)
well theres your problem then. goto honda a buy to pedal pads. they're $2.50 a piece. or you could just bypass the switch by unplugging the clip on the top one and jumping the connectors with a wire.
Old Sep 3, 2008 | 02:34 PM
zip_tied_bumpers's Avatar
I agree with bonestock98gs I think its a grounding problem or possibly a ignition issue. : )
Old Sep 3, 2008 | 05:06 PM
hyrev20's Avatar
when i check the ecu it only blink once so it was telling me that nothing was wrong. Check the starter at autozone and advance auto parts the starter is all good.....now i gots a new main relay from honda same problem click click mayn nuts huh!!! Now on my clutch pedal and that stopper was broken could that be the problem !!! and i cant find the gas pedal one too so is that all the problem too whoa crazy
Old Sep 4, 2008 | 12:04 AM
OO WOW really cus i bought mines for 1.50 very cheap ..i just connected the + to he ground and and - to the Plus works PERfect
Old Sep 4, 2008 | 01:10 AM
yeah you could have messed up your clutch sensor, if its not pressesed it wont let the car start
but check that ignition switch, and as for the relay, theres nothing wrong with it, mine also clicks
you just can't hear it when the motors starting.
but you can since its not even turning over.
Old Sep 4, 2008 | 01:55 AM
efluvinboy's Avatar
i had dat same problem wit my 91 hatch with ls swap....i was missin the ground from the tranny to the frame
