1996 honda civic stereo configuration
Old Aug 29, 2008 | 04:46 PM
crvsam's Avatar
Default 1996 honda civic stereo configuration
im putting an aftermarket stereo in my honda civic. which wires go to what? for all the speakers and stuff?
Old Aug 29, 2008 | 05:06 PM
94EG8's Avatar
Seagull Management
Default Re: 1996 honda civic stereo configuration (crvsam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvsam &raquo;</TD></TR><TR><TD CLASS="quote">im putting an aftermarket stereo in my honda civic. which wires go to what? for all the speakers and stuff?</TD></TR></TABLE>
Just go to your nearest store that sells car audio stuff, buy the adapter harness for your car, splice this onto the harness that came with the new stereo, the aftermarket wire colors are standardized so you just have match the colors up between the adapter harness and the stereo harness, then just plug it into the factory honda plug. remember to do a good job and solder and put shrink tubing over your connections, or failing that at least use good butt connectors.
Old Aug 29, 2008 | 07:07 PM
Unit44justin's Avatar
Here you go this site will give you step by step instructions.
http://www.installdr.com/Insta...3.pdf
I mounted my deck in the spot under the cig lighter and left the normal head unit in the normal spot
1sickef9
13
Mar 26, 2009 05:09 PM
crvsam
Audio / Security / Video
Aug 30, 2008 09:44 AM
CeeJayy
Jun 15, 2007 09:49 AM
miksew
Aug 4, 2006 02:57 PM
thelonerangers
Oct 1, 2005 02:26 PM
