Radiator wiring question
Old Aug 29, 2008 | 02:00 PM
MJOLNIRvTEC's Avatar
Default Radiator wiring question
Okay so I just got my hands on a moshimoto half radiator for a civic si, and a moshimoto slimfan. Quick question in regards to wiring, does just one fan come on at a time, or do they both flip on. If both does it really matter which electrical hookup i use, or should i splice both my old hook ups together and then tie it into the harness or just hook up the passenger side and not use the drivers side? Thanks alot guys
Old Aug 29, 2008 | 02:15 PM
Sir Kyle's Avatar
Default Re: Radiator wiring question (MJOLNIRvTEC)
I pulled the driver side fan out a while ago and I havn't had any problems. I think you could just use the passenger side by itsself.
Old Aug 30, 2008 | 05:59 AM
97ludedude's Avatar
Default Re: Radiator wiring question (Sir Kyle)
The pass side should be the radiator cooling fan while the driver side is the condensor fan. . . (only on when the a/c is turned on) makes the a/c cooler. If you only run one fan it will be fine.
Old Aug 30, 2008 | 06:01 AM
97ludedude's Avatar
Default Re: Radiator wiring question (97ludedude)
test the leads for voltage though i could be backwards on which one is which. can anyone verify which is the rad. cooling fan. Thanks
zapzach
Apr 19, 2013 03:57 AM
devils_civic
May 7, 2008 12:02 PM
iwantspeed
Jan 24, 2007 10:37 PM
teler86
Apr 7, 2006 05:47 AM
