search function is now retarded, AC with b-series???
Old Aug 29, 2008 | 01:52 PM
I CRX I's Avatar
Default search function is now retarded, AC with b-series???
do to the new retarded way of searching, it doesnt make it easy to search for the EF AC b-series threads and nothing is covered in the FAQ section but would anybody know which treads would have a cheap way of mounting the stock AC compressor to a gsr motor in a CRX? i know of the haport kit but im looking for a cheaper method. 200 bucks for a piece of metal just doesnt appeal to me
Old Aug 29, 2008 | 02:22 PM
traxxasx's Avatar
Default Re: search function is now retarded, AC with b-series??? (I CRX I)
hasport, or innovated.
you can diy the stock bracket, theres a thread on here somwhere.
but it takes cutting measuring and welding.
Old Sep 9, 2008 | 07:04 PM
I CRX I's Avatar
any other suggestions? ive heard the del slo AC bracket may fit with little to no modding?
Old Sep 9, 2008 | 08:05 PM
gunnerman's Avatar
Default Re: (I CRX I)
del sol bracket wont fit the ef compressor....only 2 or 3 bolts will match up. i bought an innovative mount but you'll need a stock ef pulley to put on it. you'll need a slim fan for the condensor but other than that everything else will fit. i have a b16 in my ef with a/c.
Old Sep 10, 2008 | 02:54 AM
rbwdriven's Avatar
a company called hcp also makes a bracket.
lot cheaper.
I got mine off the bay for $80.
bolts right up to a saden compressor.
Old Sep 10, 2008 | 08:52 AM
stegs's Avatar
Default Re: (rbwdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbwdriven &raquo;</TD></TR><TR><TD CLASS="quote">a company called hcp also makes a bracket.
lot cheaper.
bolts right up to a saden compressor.</TD></TR></TABLE>
I can confirm HCP made AC brackets for the b series powered crx using the Sanden AC compressor. The larger Futusu compressor will not fit.
The trouble might be finding the HCP mount. I looked for many months and finally found one at hmotorsports.com for $125. At that time, I was told it was the last one and that HCP wasn't making them anymore.
Look around, there may very well be some left second hand. Otherwise you'll be looking at fabricating something, which I am sure will be no small feat. Otherwise, get the expensive hasport one.
Old Dec 5, 2008 | 12:20 AM
JDMEk33's Avatar
I know its been a while but hcp still makes the bracket for 125 here you go!!
http://www.racingworks.com/hcp_engin...wap_mounts.htm
89usdmSI
Mar 24, 2011 02:10 PM
''Simon''
Feb 8, 2008 03:50 AM
gunnerman
May 9, 2007 04:36 PM
JokerTypeR
22
Dec 22, 2006 10:51 AM
STK B16
11
May 30, 2002 08:59 PM
