CAR SHAKING!!!!
Hey i have a 92 honda hacthback. swapped. when i drive the car is shakes. but only when i am giving it gas. not when i am in neutral and rolling or even when im breaking. only when gasing. even the littlest bit. if anyone has a clue pleaseeeeeeeeee help me out. Thanks a lot.
Nick
Nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rSol93 »</TD></TR><TR><TD CLASS="quote">motor mounts possibly</TD></TR></TABLE>
what motor mounts are you using?
I was thinking the same thing while I was reading it. Check the mounts, make sure they are okay and everything and report back.
i have stock mounts. but i know it has nothing to do with that. i can feel the passenger side wheel shake as if a ball joint or tie rod was loose. but i even changed both lower inner and outter control arm buchings and aslo tightened everything under there. tomarrow im getting an alignment hopfully that will fix it if not i dk. im lost
wfocrx
14
Oct 31, 2007 01:17 AM
