ABS light reset on 99 GSR
Hey guys,
i couldnt find anything on how to reset an ABS light on my gsr searching the forum(maybe i suck at searching?) but anyways...i have a GSR that has an ABS light on. Acura dealer did a diagnostics on it and it was a fail/safe relay that needed to be changed. I replaced the relay but of course the light didnt reset. Anyone knows how to reset this?
Thx
Thx
Pull the codes. There is still most likely a problem.
You can pull the backup fuse in the underhood fuse box as well to clear the codes. If there is a problem, the codes will reaapear.
are there any air in the brake line or are the piston leaking, cause it happened to my dc once, the piston was leaking, so no matter how i reset it, it still came on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonni2000 »</TD></TR><TR><TD CLASS="quote">are there any air in the brake line or are the piston leaking, cause it happened to my dc once, the piston was leaking, so no matter how i reset it, it still came on</TD></TR></TABLE>
i dont think air in brake line will set the light.
more like sensor(s) or ABS unit. brake will work just like it should, just not with ABS.
Blaze45
Mar 12, 2013 02:59 PM
