obd 1 d15b in 88 civic hatch HELP!!!!
here is what is going on
88 civic hatch coverted to mpfi, vtec, obd 1
tested for contiuity and checked out- dizzy wires each and every one in correct spot and making contact same with every injector signal wire and every injector ground of the fancy obd 1 plug that replaces resistor box wich also checks out as far as good grounds.
i am stumped. i have tried replacing one of the 4 injectors and setting them all up facing the sky and had a friend hold them to the rail wich has fuel pressure btw and i crank it and hardly any fuel comes out at all but the same with the one i just replaced.
i guess let me know if you need to know anything else.
good spark btw
so i have spark, good timing and compression, fuel pressure at the rail,
fuel is not passing threw the injectorssssss
im about the break the windows out lmk thanks, and jk
good spark btw
sg
Sep 8, 2008 09:11 PM
