Instrument cluster won't light up on 98 Integra
Old Aug 28, 2008 | 07:56 PM
nccj72's Avatar
Default Instrument cluster won't light up on 98 Integra
I have a 98 Integra I put a new stereo in and when I got done the stereo works great but the dash lights would not come on. The idiot that had this car before me had a 20 amp fuse in the illumination slot so the fuse did not blow. It looked like it may have gotten hot because one side was bent a little and it did not look right. My question is what would burn up or where do I need to look first to find out what the problem is? I am going to check some more fuses but if this is not the problem what else can I do?
Old Aug 29, 2008 | 10:55 AM
styles671's Avatar
yeah check the fuse if not then check the illumination switch... u might have lowered it..
Old Aug 29, 2008 | 04:52 PM
jonni2000's Avatar
Default Re: Instrument cluster won't light up on 98 Integra (nccj72)
or the harness is burned or melted
Old Aug 29, 2008 | 04:54 PM
jonni2000's Avatar
since that he had a 20 amp fuse in it, there might be too much votage on the harness and causing the melt, it happened to my ek before, what you could do is to rewire the harness and the light should come on
jdmWONG
Honda CR-V & Element
Dec 31, 2011 01:52 PM
Cap'N Chronic
Dec 12, 2011 06:54 AM
JUICED COUPE
Mar 26, 2009 04:55 PM
Roofrack
Sep 22, 2008 01:43 PM
Kr4nG
May 18, 2008 05:10 AM
