SQUEAKY CLUTCH, already searched no HELP
Old Aug 28, 2008 | 07:46 PM
taimysho0's Avatar
Default SQUEAKY CLUTCH, already searched no HELP
hey i got a 00 civic and out of nowehre my clutch starts squeaking when i press all the way down and when i release off the clutch it squeeks again. i searched and they say u need to oil the ball joint or the clutch fork or something. i tried oiling up the ball joint with wd40 but still doenst fix the problemo. and i dunno where the clutch fork thing that ppl are talking is. so if sum1 has suggestions or can tell me where the clutch fork thing is, let me know. thanks
Old Aug 28, 2008 | 08:02 PM
taimysho0's Avatar
Default Re: SQUEAKY CLUTCH, already searched no HELP (taimysho0)
bump
Old Aug 28, 2008 | 08:05 PM
6footmidget's Avatar
i have the same problem! but no answer to it :[ i would like to know why this happens too!
Old Aug 28, 2008 | 08:49 PM
batallic's Avatar
input shaft bearing, possibly
Old Aug 28, 2008 | 08:57 PM
Dkober101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taimysho0 &raquo;</TD></TR><TR><TD CLASS="quote">hey i got a 00 civic and out of nowehre my clutch starts squeaking when i press all the way down and when i release off the clutch it squeeks again. i searched and they say u need to oil the ball joint or the clutch fork or something. i tried oiling up the ball joint with wd40 but still doenst fix the problemo. and i dunno where the clutch fork thing that ppl are talking is. so if sum1 has suggestions or can tell me where the clutch fork thing is, let me know. thanks</TD></TR></TABLE>
i had the same problem it pissed me off like crazy but then i just ignored it and it went away...............
Old Aug 28, 2008 | 09:06 PM
taimysho0's Avatar
please if any1 knows how to fix this let me know and tell me where it is. its driving me NUTS
btw
nuts on the wall-walnut
nuts on the chest- chestnut
nuts on your chin- my d*ck in your mouth!
Old Aug 28, 2008 | 09:15 PM
tekniq's Avatar
new clutch
Old Aug 28, 2008 | 09:54 PM
reyrey2006's Avatar
It could be the throw out bearing.
Old Aug 28, 2008 | 10:26 PM
tazeat's Avatar
I doubt its the fork, but to get to the fork look where the hydraulic line goes to on the front of your transmission, thats your slave cylinder. Underneath the boot that goes on to the transmission is where the fork is, I wouldn't spray wd40 on it, needs real grease (brake lube preferably).
Old Aug 29, 2008 | 03:25 AM
geneeunit's Avatar
bump for the cause.
i've had this issue since february and it seemed to go away, but its back now.
Old Aug 29, 2008 | 03:48 AM
nekoabandoned's Avatar
Default Re: SQUEAKY CLUTCH, already searched no HELP (geneeunit)
you need to use a thicker lub like axle grease and its a normal honda sound, everyone stop trying to freak this kid out.... "new clutch"
Old Aug 29, 2008 | 06:44 AM
Pothole987's Avatar
Default Re: SQUEAKY CLUTCH, already searched no HELP (nekoabandoned)
I have the same Problem AFTER i put a new centerforce clutch in my car ( yes i changed the throwout bearing and the flywheel one). i figure its because the clutch is heavier.
Old Aug 29, 2008 | 09:07 AM
R883's Avatar
Default Re: (tazeat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tazeat &raquo;</TD></TR><TR><TD CLASS="quote"> thats your slave cylinder. Underneath the boot that goes on to the transmission is where the fork is, I wouldn't spray wd40 on it, needs real grease (brake lube preferably).</TD></TR></TABLE>
Grease up the slave cylinder and it will go away
Your clutch is fine
Old Aug 29, 2008 | 10:53 AM
s2kholic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tazeat &raquo;</TD></TR><TR><TD CLASS="quote">I doubt its the fork, but to get to the fork look where the hydraulic line goes to on the front of your transmission, thats your slave cylinder. Underneath the boot that goes on to the transmission is where the fork is, I wouldn't spray wd40 on it, needs real grease (brake lube preferably).</TD></TR></TABLE>
yupyup an annoying sound but a simple fix
siisgood00
Feb 18, 2005 07:29 PM
.water
Oct 16, 2004 05:24 PM
JdmFront619
Oct 28, 2003 12:25 PM
