Cluster problems (please help!)
Hey H-t i have a '91 HF that i bought with a JDM D15B but didnt run due to a bad transmission. So i ended up swapping out the entire swap for a SOHC ZC and a 91 CRX SI transmission. At the time the cluster wasnt my main concern so i wasnt paying attention if it worked or not. Well when i swapped it out the alternator on the ZC was bad so it kept draining the battery when i was smoothing out the wrinkles in the idle and such i noticed the cluster didnt work at all, even when the car was on. I thought it was the alternator so i got a new alternator and a new battery and now only the battery light works. Everything is plugged up, however i am clueless as to what could be the problem. The car used to have an alarm, but it was removed and it has an OBD-0 to OBD1 conversion harness with a stock 92-95 Civic ECU. Also now the key warning beep is on ALL the time even when im driving. PLEASE HELP ME H-T!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">Fuse #1. COntrols the tach, temp gauge, warning lights, and turn signals</TD></TR></TABLE>
wow i missed that one...under the hood or dash?
for fuses i just pull um out 1 by 1, it takes a long time, but it lets you know whats bad off the bat instead of guessing at it. just pull um with some needle nose pliers and check
replace any bad fuses and if you still have the problem you could have burnt a relay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NFRap1 »</TD></TR><TR><TD CLASS="quote">
wow i missed that one...under the hood or dash?</TD></TR></TABLE>
Under the dash
Under the dash
this fuse was burnt out...replaced it but havent cranked it i need my battery from a friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">Good luck with it
Mine blows that same fuse as soon as the car is running. Ive traced it down to my distributor
was it the cap and rotor or the entire dizzy?
was it the cap and rotor or the entire dizzy?</TD></TR></TABLE>
The wiring on the inside of the dizzy. I ended up just ordering one.
lookes burnt, so that could be it, but before repair you need to see why it burnt so your dont burn it again, look for wires that are grounding out. or some scorced metal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammergunner »</TD></TR><TR><TD CLASS="quote">lookes burnt, so that could be it, but before repair you need to see why it burnt so your dont burn it again, look for wires that are grounding out. or some scorced metal</TD></TR></TABLE>
its actually rust and corrosion...i actually have a hunch of what the problem is ill check it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NFRap1 »</TD></TR><TR><TD CLASS="quote">i spliced my gauge wire to the gauge brightness wire so it was getting power but it still doesnt work...im getting frustrated
this was stupid and ineffective dont do this lol...i did however remove my entire dash and replaced the grey box behind the fuse box and the tachometer started to work...also when i checked for power at the temperature wire on the cluster it worked momentarily as i touched it but then it dies as soon as i remove the fuse tester...the lights are still inactive at this point as well
</TD></TR></TABLE>this was stupid and ineffective dont do this lol...i did however remove my entire dash and replaced the grey box behind the fuse box and the tachometer started to work...also when i checked for power at the temperature wire on the cluster it worked momentarily as i touched it but then it dies as soon as i remove the fuse tester...the lights are still inactive at this point as well
