B16a in a 90 dx, the Temp gauge no longer workin?
Old Jul 24, 2002 | 07:39 AM
91sifreak's Avatar
New User
Default B16a in a 90 dx, the Temp gauge no longer workin?
I got a 90 dx that had a b16a in but none of the wiring was done, the plug on the right side shock tower was totally different so i re-wired a dx harness, so the enegine starts, and it runs pretty strong no misses no stumbles or anything but the temp sensor no longer reads the engine temp. it is weird as hell, but if I dissconnect the plug from the head the ecu gives a code 6 on the ecu, coolant temp sensor. Help me out please, thanks.
Old Jul 24, 2002 | 10:11 AM
91sifreak's Avatar
New User
Default Re: B16a in a 90 dx, the Temp gauge no longer workin? (91sifreak)
anybody??????
Old Jul 24, 2002 | 11:01 AM
USDM 4G VTEC's Avatar
ur coolatn temperature sensor might be shot
u might wanna get a new one
but before u do , make sure theres no cuts, or missing conectors, os anyhting loose....
and u might wanna check the sensor before u replace it .
-To check the sensor, check the resistance value of the coolant temp sensor..while its cold....ti should be anything between 2,200 to 2,700 ohms.... Next start ur engine and warm it up until its hot.... now check thge resistance and it should be lower, anywhere from 280-350 ohms..... if ur readings are good, then ur sensor its ok and then u got a problem anywhere in between the ECU and the sensor.. check for bad conectors, loos pins, cuts, pinches, all that kinda stuff...
hope it helps
Old Jul 24, 2002 | 02:31 PM
ZColeon's Avatar
New User
Default Re: B16a in a 90 dx, the Temp gauge no longer workin? (JDM EF9)
yup hes on the money, but i call it a sending unit, this tells your fans to kick on etc, its like 21.00 here in fla
Old Jul 25, 2002 | 04:15 AM
91sifreak's Avatar
New User
Default Re: B16a in a 90 dx, the Temp gauge no longer workin? (ZColeon)
thanks, i will definately try that, thanks for the in put all.
joestud
Sep 14, 2013 01:58 PM
wakawu
Jan 8, 2012 07:17 AM
dohcvtecpower
Sep 30, 2010 05:11 AM
