Crazy noise by the passenger front wheel!!!
My car (94 accord EX) started making this serious clunking/vibrating/shaking feeling. It happens when I am driving an slightly turn the wheel right. If I turn the wheel more it goes away. It doesnt happen at all if I slightly turn the wheel left. It happens on and aff acceleration, even if coasting. It causes the whole car to shake and vibrate.
It doesnt sound like cv joints of tie rods. Can anyone help me. thanks
Ok, i just changed my bearings... but the noise is still there.
At least my wheel stopped whobbling... any more ideas? I was told it may be the stabilizer bar bushings and tie rod end...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyonda »</TD></TR><TR><TD CLASS="quote"> I was told it may be the stabilizer bar bushings and tie rod end...</TD></TR></TABLE>
It def could be a tie rod, but it also sounds like an a arm is bent or loose.. check that out. And also check your suspension on that side.
for a tie rod end... does the bushing go bad or does the tie rod itself gets damaged? i saw some energy tie rod bushings and wanted to know if they're worth a try
taguchi09
Jul 19, 2011 06:44 AM
J.nguyen
Sep 17, 2006 05:28 PM
