Oil light flickering
Old Aug 28, 2008 | 10:00 AM
fryguy190's Avatar
Default Oil light flickering
well when i idle my oil light flickers. but i check the car and it has plenty of oil. idk but i think it could be my oil pump.
and now all the sudden my car will throw a check code when i step on it and my vtec wont engage anymore. until i restart the car. then its fine again. until the next time i step on it.
Old Aug 29, 2008 | 06:21 PM
geebs's Avatar
Default Re: Oil light flickering (fryguy190)
the oil pump could be a possibility. could also be main/rod bearings.
Old Aug 29, 2008 | 07:54 PM
crxcess's Avatar
Default Re: Oil light flickering (geebs)
might be an oil pump, you need to hook a gauge up to it and check it before it ruins your head and cam.
Old Aug 30, 2008 | 09:27 AM
94EG8's Avatar
Seagull Management
As stated above probably the oil pump, but it could also be the sending unit.
Old Aug 30, 2008 | 11:24 AM
fryguy190's Avatar
Default Re: Oil light flickering (94EG8)
its not the oil pump. i just started having a [freak]ing rod knock.
Old Aug 30, 2008 | 01:00 PM
geebs's Avatar
low oil pressure for awhile will destroy bearings. the oil pump could have started the issue.. the bearings could be a result of the low pressure for awhile..
Old Aug 30, 2008 | 01:33 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fryguy190 &raquo;</TD></TR><TR><TD CLASS="quote">its not the oil pump. i just started having a [freak]ing rod knock.</TD></TR></TABLE>
Not so fast there, you may have rod knock, but thats the result of a bad oil pump most likely.
Old Aug 30, 2008 | 02:11 PM
sohcvtec1995's Avatar
wait wait.. your oil light was flickering and yet you tried to engage vtec??? wow..
Old Aug 30, 2008 | 02:23 PM
mr2ttd's Avatar
If there is low oil pressure at the VTEC solenoid, there will be a CEL for that.
Old Aug 31, 2008 | 06:57 AM
geebs's Avatar
Default Re: Oil light flickering (mr2ttd)
maybe he's trying to blow it up..
i'd recommend a rebuild now..
or a swap..
Old Aug 31, 2008 | 08:13 PM
fryguy190's Avatar
i just blew up the motor yestrday. im swaping a D16z6 to a B18C3 (GSR). or if i can afford it, a B18C5!!!
88turdbucket
Dec 20, 2008 10:27 AM
94ludeJDM
May 4, 2007 06:13 PM
slipperyduck
Feb 16, 2006 09:52 AM
b16 matt
11
Mar 18, 2004 02:11 PM
