CRX DX, to 0bd1 B18 wiring help
Old Aug 28, 2008 | 09:14 AM
thapimpfromchi's Avatar
Default CRX DX, to 0bd1 B18 wiring help
Ok. I've tried looking all over on this site all morning reading through countless threads, and I havent found a clear description on what im supposed to do.
As the title states, i am putting a 1995 LS motor into a 1991 Crx.
When I bought the car it didnt have an engine, or harness or anything. The previous owner had a newer d series swap done, so it's already been converted for mpfi. Thats about all I know of it.
So, I was told by many people that I need to get a harness specifically for my car, so I did, I got a crx dx harness. Then I was told I needed to get the plugs from the LS motors harness and switch them onto the CRX harness. So i went and bought an LS harness.
Thats as far as I know.
I don't know what plugs to switch, I don't know which to make longer, i don't know anything after that. I want to have the harness on there, and working before I drop the engine in the bay. Cuz its a bitch reaching beind the engine tryin to plug stuff on.
Any help/info/link/pics would be highly appreciated.
Also, for more info, check out my build thread link in my sig. Thanks.
Old Aug 28, 2008 | 09:26 AM
MyHotsh's Avatar
Default Re: CRX DX, to 0bd1 B18 wiring help (thapimpfromchi)
http://RYWIRE.COM is all you need. Send them both harnesses and they will combine them and send you a plug n play harness for your motor...
Old Aug 28, 2008 | 09:41 AM
Default Re: CRX DX, to 0bd1 B18 wiring help (MyHotsh)
yea, i thought about that. but that also costs 280 dollars. If i can find a diagram and do it myself, i'd much rather go that route.
Old Aug 28, 2008 | 09:54 AM
MyHotsh's Avatar
http://www.boomslang.us/obd0_1.pdf
http://hondaswap.com/hybrid-ed...pter-
http://hondaswap.com/reference...28667/
Keep searching, lots of info out there.....
Old Aug 28, 2008 | 10:31 AM
ooh. good links. thanks alot.
Old Aug 28, 2008 | 10:49 AM
team2dcrx's Avatar
you have to switch the distributor plugs,delete the resistor box(if it has one), extend fan swith plug,wire up 4 wire 02 sensor..and maybe lengthened the map sensor wires..and do a obd0 to obd1 jumper harness......cake
Old Aug 28, 2008 | 11:42 AM
slicedbreadno2's Avatar
Default Re: (team2dcrx)
Just search more and try it out yourself if you don't succeed send it out to rywire
Old Aug 31, 2008 | 05:23 PM
Default Re: (slicedbreadno2)
thanks for the links and stuff. I'll have to do some homework. I was hoping to find a clear like.. picture by picture (step by step), write up. but no luck there. i've never done anything like this before so im a little skeptical. I dont wanna mess anything up cuz it was a bitch tracking these 2 harnesses down inthe first place. lol
Old Sep 5, 2008 | 10:03 AM
Default Re: (thapimpfromchi)
i'm going to attempt it today. I just picked up a soldering gun, some heat shrink tubing, a heat gun, some wire, a 4 wire o2 sensor. and i have both harnesses and the jumper harness, so hopefully with a little luck and patience i should be able to get this working. Lets hope anyways.
Old Sep 5, 2008 | 10:07 AM
MyHotsh's Avatar
Good luck with it!!!!take your time and do it right....
Old Sep 5, 2008 | 01:11 PM
Default Re: (MyHotsh)
no luck. check my build thread for the problems i encountered if you'd like.
previous owner did some frankenstein wiring job and idk what the hell is what.
Old Mar 8, 2009 | 08:54 AM
CrazyKoreanCrx's Avatar
*When I bought the car it didnt have an engine, or harness or anything. The previous owner had a newer d series swap done, so it's already been converted for mpfi. Thats about all I know of it.
So, I was told by many people that I need to get a harness specifically for my car, so I did, I got a crx dx harness. Then I was told I needed to get the plugs from the LS motors harness and switch them onto the CRX harness. So i went and bought an LS harness.*
--As you stated, my personal opinion if it was original converted to mpfi and you bought a new engine harness you'll have to converted it again to mpfi, Because the si and hf model are already have the mpfi.
*team2dcrx --you have to switch the distributor plugs,delete the resistor box(if it has one), extend fan swith plug,wire up 4 wire 02 sensor..and maybe lengthened the map sensor wires..and do a obd0 to obd1 jumper harness......cake *
--team2dcrx is right with this part.
I just dont know what else your missing or need help with?
freddy chavez
Dec 25, 2012 12:28 PM
bodiez
Apr 3, 2011 07:36 PM
Preston_91EF
Dec 26, 2009 03:13 AM
crew08 (girlygirlracer)
Mar 18, 2003 02:49 PM
