Bearings questions, Z6 pistons/Rods A6 crank and Block
Old Aug 28, 2008 | 08:34 AM
alupso's Avatar
Default Bearings questions, Z6 pistons/Rods A6 crank and Block
I’m doing my first basic simple rebuild of an engine and had a question about the proper bearings to use.
I’m planning on using a D16A6 block and crank with D16Z6 rods and pistons and wanted to know which main and rod bearings to use and should I use the Z6 rings?
Old Aug 28, 2008 | 07:01 PM
onefastek9's Avatar
same crank, same bearings, same piston, same rings.
Old Aug 29, 2008 | 05:14 AM
alupso's Avatar
Default Re: (onefastek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastek9 &raquo;</TD></TR><TR><TD CLASS="quote">same crank, same bearings, same piston, same rings.</TD></TR></TABLE>
So use the A6 bearings for the crank and rods and the Z6 rings?
Old Aug 29, 2008 | 12:49 PM
onefastek9's Avatar
Default Re: (alupso)
same bearing from same block. y are you using z6 piston? you want to change the compression?
Old Aug 29, 2008 | 12:53 PM
alupso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastek9 &raquo;</TD></TR><TR><TD CLASS="quote">same bearing from same block. y are you using z6 piston? you want to change the compression?</TD></TR></TABLE>
I have a A6 block with crank and the Z6 rods and pistons are the only ones I could find at a decent price.
Old Aug 29, 2008 | 01:09 PM
onefastek9's Avatar
ok then, well as long as they are the same size rods you can use them, the pistons should be the same. I thinkn the rods are too but don't hold me on that...,
Old Aug 29, 2008 | 01:40 PM
alupso's Avatar
I was checking rings and they are the same for the Z6 and A6.
Old Aug 29, 2008 | 07:07 PM
onefastek9's Avatar
like I said before, not too sure on rods but sure the pistons are the same, so saying ofcouse the rings will be the same. just not too sure on rods as b18 ls are different then b18 gsr even tho they both have 1.8L engines.
Old Aug 29, 2008 | 07:17 PM
alupso's Avatar
I actually look on Hondapartsdeals.com and the Z6 and A6 rod part numbers were the same so I think I'm going to get A6 bearings and Z6 rings just to be safe
Old Aug 30, 2008 | 05:31 PM
97grnrs's Avatar
Default Re: Bearings questions, Z6 pistons/Rods A6 crank and Block (alupso)
they are all the same. i mix and match all the time.
Hondamonster
May 27, 2007 08:24 PM
mattie_96
Sep 30, 2006 02:51 PM
dohcdelsol
May 3, 2006 09:20 AM
caspers_hatch
Mar 20, 2005 07:52 PM
turbo sol
Oct 20, 2003 07:07 AM
