got my lowering springs on
Old Aug 28, 2008 | 03:50 AM
holly123890's Avatar
Default got my lowering springs on
here is the link IT AT THE BOTTOM
i was also wondering if i need my car relined,(my car use to pull to the right when i had stock springs, now that i have coilover, my car drives straight.) and am i going to need new shocks? or should i wait b/c i have my rims sitting on the front porch waiting to be painted, and waiting to get new tires. and if thise stuff needf to be done right away can i wait 2 week till i get paid?
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Aug 28, 2008 | 04:21 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: got my lowering springs on (holly123890)
If you lowered it, yes you need an alignment. It's not so much about the left/right pull as it is about improper and dangerous tire wear. If you don't get an alignment, your tires will wear out very quickly, usually around the inside edge. If you're putting new tires on in 2 weeks, it's probably okay to wait until then.
From what I've heard, you should change your shocks with lowering springs.
Old Aug 28, 2008 | 05:57 AM
Default Re: got my lowering springs on (Vindicator9000)
Ok so the bounciness isn't all that bad than ? And what does an alignment usually cost? the shocks looked fine when my boyfriend put the springs on. any other suggestions? would anyone not purchase the coil overs i got?
Old Aug 28, 2008 | 06:19 AM
here is the link to wear i bought my springs are they good
Old Aug 28, 2008 | 06:22 AM
Wakes4Fun's Avatar
Alignment's usually run around $70. You should definitely get some aftermarket shocks asap, because if you are running stockers they will eventually blow out
Old Aug 28, 2008 | 10:55 AM
ok thanks alot i loved the help
Old Aug 28, 2008 | 11:45 AM
sde780's Avatar
yea, and those ebay coilovers suck. It may be lowered, but the ride is gonna be really bouncy. Get some quality lowering springs. I like to suggest Tein S-techs if you're on a budget
na+b18c_hatch
Honda Civic (2006 - 2015)
Jul 18, 2011 07:28 PM
PhatRoyale
Suspension & Brakes
13
Oct 8, 2008 07:58 PM
kixcrx
10
Jan 23, 2007 12:41 AM
ezekel
Suspension & Brakes
Sep 21, 2006 10:47 AM
BiziggumS
Suspension & Brakes
May 18, 2005 01:03 PM
