b16 O2 sensor
i have thrown a code 2, which means i need an o2 sensor.. this also means that it is the #2 or downstream sensor.. i have looked and there is not one on the manifold and only one before the cat. maybe i am not looking in the right place to find the other one or is there one???
also what would i order the sensor for??? 94 del sol si??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LUKE 92 GS-R »</TD></TR><TR><TD CLASS="quote">i have thrown a code 2, which means i need an o2 sensor.. this also means that it is the #2 or downstream sensor.. i have looked and there is not one on the manifold and only one before the cat. maybe i am not looking in the right place to find the other one or is there one???
also what would i order the sensor for??? 94 del sol si??</TD></TR></TABLE>
So I assume you have a '94 del Sol Si with a B16 swap?
The '94 del Sol VTEC (that comes with the B16A3) appears to only have one oxygen sensor on or near the catalytic converter.
The '94 del Sol Si (which comes with the D16Z6) shows an oxygen sensor on the exhaust manifold.
I suppose this has to do with OBDI, which I'm not really familiar with at all.
78F350
Jan 26, 2012 08:17 PM
dcook
Mar 30, 2004 12:45 PM
