94 ACCORD outside molding (black). NOT SILVER WINDOW TRIM...
I cannot figure out how to pinch the clips on all the plastic clips holding the black outside molding on. If someone can post a diagram or STEP BY pictures I would appreciate it. thanks. My model is 94 Accord EX 2dr.
I had no problem with the one screw and the one clip under the door handle behind the door panel. But the one I cant get is on that same piece of trim but at the front of the door, where the hinge is. It seems to be stuck right behind where the hinge is and the air vent or where all the electronics connect into the door... thanks for any post on this subject by the way!
Ah the plastic colored one?
Take off the speaker grill (just kinda up and out) then take a hold and slip your hand behind the door panel near where the speaker grill is and start sliding it towards the rear of the door and pulling.
All the little clips should pop out and that colored one you're talking about should pop out too. I've never actually popped it out by itself.
It will also probably help to take out that black mirror triangle, I think if you swing the top end out towards you and then pull up it'll come right out.
Looks like I'm gonna try that first thing tomorrow!!! ill get that bitch off some how.. I just can't break the clips cause the only place I can get them from right away is HONDA dealership and that **** adds up fast!! ha thanks, we'll see what happens.
LOOKALIKe_eh2
Jan 3, 2005 05:47 PM
