i have a turbo crx b16a and the temp gauge is up and down and all around.
when im driving on the freewayy it goes wayy up when im driving. and i know its not right cuz when i take it outta gear and then put it back right after its starts to go down, than in a min it goes back up and i know when its hott it would not go down that fast.
so anyone any answers lmk asap thanks alot
I am having the same annoying problem right now... I give my cluster dash a smck and then it drops back down. been too lazy to pull it apart so I just keep smacking it!
check for a loose connection in the cluster.
Or either you need to bleed your coolant system..
if it gets hot when your giving it gas and then when you put it neutral or pull over it goes back down...its most likely a warped or cracked head...i had this same problem...with a d15b turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team2dcrx »</TD></TR><TR><TD CLASS="quote">if it gets hot when your giving it gas and then when you put it neutral or pull over it goes back down...its most likely a warped or cracked head...i had this same problem...with a d15b turbo</TD></TR></TABLE>
i dont think its that bad. cuz it doesnt get in the red ever just real close but not in. and it does cool down but only when i down shift or pull over and throw sum revs for sum reason.
It is more likely that you either have a bad ground, or broken heat sensor.
If you let off the gas, the revs come down. As does the current from the alt.
Check the grounds. Especially the main ground and the one on the thermostat.
If that doesn't solve anything, take the thermostat out, and put it in boiling water to see if it's still working right.
i know what you mean, mine dose the same thing. i just got it out the shop and it gets hot as ***** under the hood... :/
are you running a full rad with your turbo and dump tube next to it insted of a half? i am that, may be it...
do you have heat wraped eg pipes? i was thinking of doing mine...
just some simple prob solvers
Is there an actual way to test the sensor to see if it works? I took my head off my b16 and installed a buddy club gasket on, car ran great after that but that dam needle started fluctuating. It's driving me crazy I'm paranoid thinking it's going to start heating up or worse heat up and not be able to tell.
Dense
10
Jan 2, 2008 07:46 PM
cthan3o3
Jul 26, 2005 09:48 PM
etp72
Jun 12, 2003 05:51 PM
