Piston Rings - Sealed Power or Beck\Arnley - 91 LS
either should be fine. if you are re ringing your stock pistons i would make sure that the rings are designed for exactly that. sealed power makes great rings but they normally have a piston to go along with them. if your stock pistons use the exact same size rings i would go that way. if they are file fit rings make sure you set your ring end gap correctly.
