Need Help CEL 16
My car wont stay on when the engine check light comes on. I checked the code and it was CEL 16... the car will stay on and drive and then sputters when the engine check light comes on. Then the car would crank but not hold idle. And when it does hold idle the car is in limp mode and will can only rev to 3500 rpm.. Where should i start with this? oh btw its an 88 civic hatch with a JDM b20 swap.. the car has been coverted to obd1 dash harness connected an obd2 engine harness
im sure its the right injectors because it started up fine before and it just started now..can it be my injectors are going bad? or is something wrong with the wiring?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 »</TD></TR><TR><TD CLASS="quote">I just had a code 16 and I switched out the main relay and bolted it to the frame. No more code</TD></TR></TABLE>
what do u mean u bolted onto the frame? meaning u grounded the main relay to the frame?
bgcrx
Feb 21, 2008 07:24 PM
