cluster
Old Aug 27, 2008 | 06:00 PM
Lil_Wyte's Avatar
Default cluster
i took a quick search but didnt see anything, 92 civic si....driving home like 10mins ago, cluster lights were on, did a U-turn and stepped on it a bit, then the lights went off, turned the lights off and clicked them back on again and they started working fine until i did a semi-hard left turn. now they wont come back on, any ideas at all? everything else works on the cluster its just the lights
thanks
Old Aug 27, 2008 | 06:39 PM
vtecb18c's Avatar
Default Re: cluster (Lil_Wyte)
you have a short somewhere or a loose ground...where?? you got me but thats definitely what it is
Old Aug 28, 2008 | 07:16 AM
Lil_Wyte's Avatar
Default Re: cluster (vtecb18c)
Where would I even look for this bad ground? Or short?
Old Aug 28, 2008 | 06:38 PM
Lil_Wyte's Avatar
bump...anyone know where to even start with this, not familiar with this at all...
Old Aug 28, 2008 | 07:10 PM
Civic9390's Avatar
you might be able to replace your fuse but thats not gonna help your shortage issue... Get an haynes manual and look at the wiring diagrams and check the grounds before you dig through your wiring.
Old Aug 28, 2008 | 07:12 PM
Lil_Wyte's Avatar
Default Re: (Civic9390)
ok so i checked my fuses and grounds and there all good, what else could i try? now there not working at all
Modified by Lil_Wyte at 4:39 PM 8/31/2008
Old Aug 31, 2008 | 03:40 PM
Lil_Wyte's Avatar
Default Re: (Lil_Wyte)
bump
tommybarrett
Jul 18, 2010 04:57 PM
EG6_978
Apr 4, 2010 12:56 PM
honda011
11
Aug 31, 2005 07:14 PM
hybrid901
Jan 30, 2003 04:40 PM
