b16 swap
Old Aug 27, 2008 | 04:02 PM
innes887's Avatar
Default b16 swap
i just found a good deal on a complete b16a3 and trans but i was wondering if i can still keep it obd-0? its goin into an 89 crx dx.
Old Aug 27, 2008 | 05:29 PM
innes887's Avatar
anyone?
Old Aug 27, 2008 | 05:48 PM
davey421's Avatar
Default Re: b16 swap (innes887)
A B16A3 is an obd-1 motor. so you could either convert the motor to obd-0 to match up your crx or change up your crx to accomadate for obd-1. both are pretty straight forward. Tons of info on all of this in the swap section.
Old Aug 27, 2008 | 05:50 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: b16 swap (davey421)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davey421 &raquo;</TD></TR><TR><TD CLASS="quote">A B16A3 is an obd-1 motor. so you could either convert the motor to obd-0 to match up your crx or change up your crx to accomadate for obd-1. both are pretty straight forward. Tons of info on all of this in the swap section.</TD></TR></TABLE> I like this nub
Old Aug 27, 2008 | 06:07 PM
innes887's Avatar
sorry what i ment was the motor is from an 2000 civic si, i though it was an a3 but i was wrong. im just wondering if the sensors are way different where i cant just swap the plugs from the b16 to my current engine harness.
Old Aug 28, 2008 | 05:33 PM
gearhead16's Avatar
Default Re: (innes887)
it uses the same plugs as a obd1 b16a some of your plugs will fit and most the the sensors i think only the distributor plug is the onyl one u gotta change i got my b16a as obd1 then converted it to obd2 for a 99 civic ex and now put it back 2 obd1 in my crx
Old Aug 28, 2008 | 06:47 PM
innes887's Avatar
i think im just gonnna keep it obd1. thanks for all the info guys. oh and one other thing, do i have to get the rear engine mount bracket cus its a hydro trans?
ef_sedan_man
May 18, 2008 08:08 AM
project ak
Jan 4, 2007 07:05 PM
IWearMyKswiss
Jun 26, 2006 04:55 AM
94SuperLudeSI
37
Nov 16, 2005 01:29 PM
turbo_ef9
12
Sep 19, 2004 07:03 PM
