Turbo B16.
Old Aug 27, 2008 | 03:53 PM
RedValve's Avatar
Default Turbo B16.
about to turbo my b16a2 with greddy kit. Running on stock block and head btw, will get a build head soon.
using crome to tune it, just want an estimate how much I will get.
Plus if anyone has the setup plz post up some pictures. thanks..
Old Aug 27, 2008 | 04:05 PM
dohczccrx's Avatar
Default Re: Turbo B16. (RedValve)
80000 horse power. do you realize that questions is the dumbest you could ask.
Old Aug 27, 2008 | 06:39 PM
RedValve's Avatar
mybad, it going to run 7lb daily, just want to get a number before everything it put in.
hopefully 190? 210? with a good tune and crank up boost if needed.
Old Aug 27, 2008 | 06:53 PM
Ek4 life's Avatar
Default Re: (RedValve)
why would you get it tuned for, don't the greddy setup come with the crap emanage system already tuned for that specific engine.... I believe that greddy setup only pushes 4 1/2 psi i believe but correct me if im wrong...
Old Aug 27, 2008 | 09:18 PM
mistahmac's Avatar
i would say around 215whp.
Old Aug 27, 2008 | 11:31 PM
solattack77's Avatar
Default Re: (mistahmac)
i've got the same setup. Running 4.8 psi right now, making 173 whp and 126 tq. This is my DD. I'm going to turn up the boost to 8 psi when i get a few more parts.
i can take some better pics if you want
Old Aug 28, 2008 | 07:49 AM
cleanej2's Avatar
Default Re: (solattack77)
what size turbo does the greddy kit use?
Old Aug 28, 2008 | 08:16 AM
2000siturboR's Avatar
Default Re: (cleanej2)
they use a dsm 18g the kit isnt bad for about 5-10 pounds but i got 14 pounds out of it and everything sucks for it doesnt make as much power that a b16 should on 14 pounds but with some bigger ingectors and intercooler and get it retuned i should make about 300
Old Aug 28, 2008 | 06:12 PM
RedValve's Avatar
damn thats really good numbers, and yes if you could post up some pics and everyting you bought to get the kit up and running.
I still need intercooler, injectors,bov and im set.
Planning to get some DSM Injector with resistor to go along with it.
just want to now what injector you run or prefer, might change it in the future.
also what did you use to tune it. thanks
Old Aug 29, 2008 | 01:05 AM
heres a couple more pics, i used precision 440cc injectors and a hondata s100 because the crome chip i had didnt work.
Basic list:
Hondata S100
Greddy Full Kit
Greddy RS Bov
Precision 440cc injectors
Greddy turbo timer
Greddy boost controller
Old Aug 29, 2008 | 07:26 PM
RedValve's Avatar
look really nice, thanks for the pix.
hoping mine will get good number too.
Planning to rune crome on it, would tuner shop burn crome chip in my ecu?how much was the tuning and how long did it take?
Old Aug 29, 2008 | 10:40 PM
i was at the tuners for about 4 hours but he only charged me $140 an hour. I had problems with crome so i just went with the hondata. So total for tuning was about $160, he felt bad for me since crome failed and i was stuck
Old Aug 30, 2008 | 11:04 AM
RedValve's Avatar
the tuner had the crome chip right? why couldnt it burnt in?
so hondata s100 cost 160 plus tuning hour?
Old Aug 30, 2008 | 11:10 AM
Yea they had the crome chip, i actually had another shop put the basemap on the chip and install it for me. For some reason the chip wouldnt let my tuner add boost tables in. I picked up the s100 for about 191 from ModaCar. And then the total for tuning was 160
Old Aug 30, 2008 | 12:18 PM
RedValve's Avatar
damn 160 for tunning hellah cheap!,
crossed finger when i go everything will go right with crome chip.
Old Aug 30, 2008 | 12:47 PM
yea it was $140 an hour but he only charged me $160 for the time that i was there
Old Aug 30, 2008 | 09:35 PM
RedValve's Avatar
anyone else have the same setup they want to share with couple of pixs?
Old Aug 31, 2008 | 02:49 PM
Ek4 life's Avatar
Is e manage really that much of a crap?
Old Aug 31, 2008 | 03:10 PM
HondaGuy951's Avatar
wow u mae 175 hp on a turbo setup?! that's sad....I make 210 on my DD all motor setup!
Old Aug 31, 2008 | 03:33 PM
Default Re: Turbo B16. (HondaGuy951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuy951 &raquo;</TD></TR><TR><TD CLASS="quote">wow u mae 175 hp on a turbo setup?! that's sad....I make 210 on my DD all motor setup! </TD></TR></TABLE>
175 at 4.8 psi, im going up to 9 or 10 when i get my boost controller hooked up
Old Aug 31, 2008 | 07:47 PM
Default Re: Turbo B16. (solattack77)
i have the greddy kit with built bottem end on 14 pounds only have 220 horse just because the injectors sucks and at about 7 grand boost drops from 14 to 10 sucks bad tuned with neptune btw. need better turbo and bigger injectors
Old Aug 31, 2008 | 08:27 PM
umair's Avatar
seems like the greddy kit produces some disappointing numbers.
home made turbo kit&gt; greddy turbo kit.
Old Aug 31, 2008 | 10:51 PM
Default Re: (umair)
o it does but its not bad if u just want it for DD or just want a little more power its not bad. but when u want more your better off build your own system.
Old Sep 7, 2008 | 03:48 PM
RedValve's Avatar
anyone else has more pictures?
Old Sep 7, 2008 | 04:26 PM
v8killaz's Avatar
well hes only running 5 psi, you could get more power out of sohc with the boost ur running.
